Question about EliteGroup K7SEM Motherboard
The USB 2 & 3 have 10 posts each and my USB plugs have 4 openings
One wire coming from the USB plug has a + symbol on each of the plugs. How do these plug in on the K7SEM motherboard?
  • EliteGroup Master
  • 4,806 Answers
The USB pinout is as follows >>>>>>
Good luck.
Posted on Jul 01, 2009
What port on the back of the hard drive do I plug the durabrand uc280 USB powered speakers into?
Hi Missy
You don't plug the speakers into the hard drive.
You should have two cables or wires
a USB cable, which you want to plug into any open USB port. the USB cable will not plug into any port other than a USB port, so just find any open one.
The second wire should be a male 3.5mm stereo jack plug.
If you have a desktop computer, look on the back for a round green hole that the stereo jack will fit into. There may or may not be a symbol of headphones. You may not have a symbol or colored hole, in that case find the two or three holes that the plug will fit into, then turn on a program that should have sound, then plug the stereo plug into each of the holes until you hear sound. If you hear no sound no matter which hole, check to make sure you do not have the sound muted.
If you are using a laptop, look for the hole with the headphone symbol.
Hope this helps.
Jul 31, 2011 | Computers & Internet
Replace spark plugs in 1997 4 cyl. ford ranger
Hello, I will suggest you get these few tools before you with the replacement.
(1) Spark plug socket with rubber insert to hold plugs in place while inserting & removing.(2) 6inch extensions for your 3/8ths inch socket wrench,(1) Swivle Socket extension for your 3/8ths inch socket wrench.(1) 1/2inch socket for exhaust manifold screws. A little quantity of anti-sieze for the spark pluggs to be applied to the pluggs if they are proving difficult to get out.
Start with the 1st cylinder at the front of the engine on the passanger side.
STEP 1.
Twist & remove the spark plug boot from the existing plug.
STEP 2.
You have to use a very small flat edged screwdriver to open the clips that hold the plug wires together.
STEP 3.
Use a 6" extension & a 3" extension & your deep socket for the spark plug.
STEP 4.
Remove the first plug and replace the old plug with a new Bosch Platinum Plus 2 prong plug and use some anti-seize on the threads and tighten to the appropriate torque.
STEP 5.
Remove the old plug wire from the coil pack. It will be going to the 2nd coil pack (located to the rear of the first coil pack) and install the new plug wire in the coil pack.
STEP 6
Repeat steps 1-7 for plugs on 2 & 3.
STEP 7.
To remove Plug #4 which is the last plug on the passanger side,you have to remove the two (2) 1/2inch bolts that holds a bracket to the exhaust manifold. Make sure you spray the studs these bolts are on with some DW-40 or liquid wrench. The exhaust manifold studs might have a lot of rust & being difficult to turn nuts off without shearing off the stud. It has some sort of aluminum box ontop of this bracket with some sensor wires coming out of it, Slip the bracket off and simply lay it to the rear of the engine to provide better access to this last cylinder.
STEP 8.
Repeat steps 1-7 for plug #4 and then Remount bracket containing the aluminum box with sensor wires.
Upon completion of the passenger side,you now have to proceed to the driver side.
STEP 1. The first cylinder at the front of the engine the spark plug wire has a grey handle sticking up next to the A/C compressor. Using some pliers (needle nose plier) twist & pull this grey handle. The spark plug boot should pop out.
STEP 2.
With the help of the small flat edged screw driver, unhook the spark plug wire clips that hold the wires together. There are 3 - One just after the 1st coil pack located at the front of the engine, another just on the other side of the valve cover and a small 2 clip located about 1/2 way back on the valve cover under the intake manifold.
STEP 3.
Remove the spark plug wire from Cylinder #1 on the Drivers side
STEP 4.With the help of the small flat edged screw driver,press the 4 connection points on the grey handle that is attached to the wire,it will separate down the middle and allow you to remove the wire, Replace the wire with the new wire,you have to ensure you line up the rubber round plugs with the round holes in this grey handle & snap it back together with the new wire in place.
STEP 5.
Hold the spark plug socket in your left hand down near the plug,feed a 6" inch extension below the A/C Compressor line (black pipe) and the A/C Compressor with your right hand and attach the spark plug socket into the extension.
STEP 6.Slip the socket onto the plug,afterwards,attach an additional 3 or 6 inch extension to the existing extension & attach your socket wrench.
STEP 7.Remove the plug & proceed to replace it with a Bosch Platinum plug & anti-seize on the threads. Feed the new Spark Plug wire over to the 1st coil pack & replace it on the coil pack.
Jul 05, 2011 | 1997 Ford Ranger SuperCab
How do I wire a double pole double throw 240 volt ge intermatic timer to 4 240 volt plugs?
You posted under GE timer, but added the brand name Intermatic.
GE and Intermatic timers are totally different.
Wiring below is for GE and will not apply to Intermatic.
Step 1) lets cover basic GE timer wiring for 240Volt load.
Be sure to set dip switches BEFORE applying power.
Step by step illustrations show on following link.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
Step 2) Load wires exit GE timer.
There are two Hot wires and 1 bare ground wire.
Step 3) Wire the outlets: You have 4 240Volt plugs.
This could mean a receptacle-type outlet like a clothes dryer outlet or air conditioner outlet.
Or it could be a twist-lock receptacle or extension-cord-type stage plug.
In all cases, look at screw color on device.
Connect Hot wires to brass colored screws.
Connect ground wire to green screw.
Step 4) Calculate total Load
Manual appears below: Look at Normally Open contacts. These contacts turn ON when timer turns ON.
http://waterheatertimer.org/15087-15207-56922-Manual-eng.pdf
Total load on all 4 plugs cannot exceed 2 HP
Generally, a 30 amp timer is rated for max 24 Amps or 6 amps per each of the 4 plugs.
Volts x amps = watts.
Take total watts and divide by 240Volts to get amps.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | General Electric GE 56941 24-Hour Outdoor...
My Acer 5532 laptop came with 2 usb ports, but usb plugs do not fit into either one....why?
The USB cable goes into the computer only one way. If you look closely on the USB plug, you will see the USB symbol (4 lines with a dot at the end) on one side. When you push in the cable in, this symbol should be on the top side. Otherwise it will not go in. The cable is designed in such a way, so the wrong pins do not come in contact.
Jan 27, 2010 | Acer Aspire 3680 Laptop
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Realistic Cardioid Dynamic mic (33-992A) mic plug wiring
i think you would save time buy just buying a usb mircophone
ive seen them getting very low in price. you risk damaging your computer if you get the wiring wrong.
Feb 22, 2009 | Audio Players & Recorders
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
EliteGroup K7SEM Motherboard Logo
704 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
