Question about Philips 20DV6942 20 in. TV/DVD Combo
Magnavox dvd vcr combo
I hve no power getting to the tv, the outlet is fine. is ther a fuse I can check?
Every other month our Magnovox big screen just stops working and will not cut on. We call the repair man and after two weeks, he always tells us it was just a fuse. We feel that we may be able to fix this. Is it possible to take off the back of the set, buy, and fix the fuse at home?
Posted on Aug 18, 2008
YES..............All of these Magnavox TV/VCR combo units have fusses in them. Be aware of the fact that some of these fuses...do NOT look like fuses. THey're small round BLACK parts which have an F on top of them. They are SOLDERED to the PC board.
I'm very familiar with these fuses. BERNIE
Posted on Jan 22, 2008
Why after power outtage dvd player don't work?
A power surge sometimes fries the unit it may have a fuse you can replace on the inside
May 14, 2015 | Magnavox Dv220mw9 Dvd Vhs Vcr Combo Player
04 lexus rx330cig outlet under ther gear shifter is not working
First check the fuse that services that outlet. That is the most likely reason for the fault.
Oct 01, 2012 | Lexus RX 330 Cars & Trucks
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
My power outlet in my 1995 Ford Mustang has stopped working. I replaced the fuses under the hood of my car with 20 amp fuses for the issue and still the power outlet isnt working. Is there something wrong...
first un plug the lighter use a test light ground 1 end and see if thare is power ive seen alot of the lighters be bad for what ever the reason if you have power to the wire with the key on its the lighter if not the best thing to do is put in a new wire to the fuse box that comes on with the key thare are always extras in the fuse box
Apr 22, 2011 | 1995 Ford Mustang
Magnavox 19MD358D experienced a power surge, will not turn on. What are the steps to troubleshoot?
The Maganvox TV was still under warranty, I called 1-800-705-2000 and talked with a TV Tech. He instructed me to unplug the TV for one minute. This is called a "hard-reset". I waited for one minute, plugged the TV directly into the outlet, turned the TV on and it worked.
The reason I plugged the TV directly into the outlet and not the power strip, is because I think the fuse burned out in the power-strip.
Nov 07, 2009 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox dvd vcr recorder will not turn on
check fuse inside on board for power u have to take a part
Oct 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tv wont turn on
outlet power and fuse check them . don't forget that if you want to replce fuse , you have to replace with a fuse with same rating
Sep 15, 2009 | Protron PLTV3250 32 in. LCD Television
Tv will not come on I have a panasonic viera th-50px80u it was connect to a power surge and the outlet has power but the cord to the tv is good and is connect to the wall outlet but tv does not come on is...
Hello
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PX80U Plasma TV
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
Philips 20DV6942 20 in. TV/DVD Combo Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
