Question about Air Tools & Compressors
Craftsman 5hp 25 gal oil free compressor. Shuts off at 30-40 psi. After bringing it to Sears service center they said it needed a cylinder replacement I opted to do it myself. Easy! Still no pressure above 30-40 psi. Now I have a new check valve and today I replaced the pressure switch and only 30 psi. The old and new pressure switches say on the bottom "on at 100psi off at 130 psi." I've also confirmed the low pressure because tools don't function well(if at all.)
  • goldtop77 Jul 01, 2009
    I did indeed make sure intake filter was clean but the cylinder kit did not include the valve plate. Visual inspection of the reed valves showed no unusual wear. There was some residue that I cleaned off. If the reeds are fatigued would that cause the compressor to shut off at such low psi?
  • 34 Answers
DID NEW CYLINDER INCLUDE NEW SUCTION & DISCHARGE VALVES? IF NOT, IT MAY BE
VALVE PROBLEM. ALSO MAKE SURE INTAKE
FILTER IS CLEAN.
Posted on Jul 01, 2009
Manual for craftsman 33 gal 6 hp 919-165500
Craftsman Portable Oil Free Direct Drive Air Compressor Parts 919 165500
Illustrations of Sears Craftsman at the link above for:
Portable Oil-Free Direct-Drive Air Compressor
Jan 30, 2018 | Craftsman Air Tools & Compressors
Why won't it pump up past 40#?
If you don't have any air leaks, the cylinder head gasket is probably bad on the pump. Easy fix for less than $10. you can get the parts you need here:
http://www.mastertoolrepair.com/sears-craftsman-919195411-p-48270.html or ebay.com. For around $50 you can get the whole rebuild kit.
May 09, 2014 | Craftsman 20 Gallon Portable Horizontal...
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a sears craftsman air compressor 5hp 22 gal tank single cyl oil free it gets up to 70 psi does not shut off but will go no higher i cant find any leaks just bought it used guy used it to paint i...
The regulator and emergency release valve need to be checked. It should shut off once the PSI hits the target pressure. If the motor is staying on and the pressure never raises above 70 lbs, then air is escaping, either the emergency prv or a seal has blown
Sep 24, 2009 | Air Tools & Compressors
Craftsman 1/3 hp compressor leaking oil
most defintly you need a head gasket but you will also need piston rings look up your local sears service center not automotive or the store you want appliance service center
Jun 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My 5hp 22gal craftsman compressor wont go above 30lbs pressure
your presure guage sensor has gone a miss you can try adjusting it but I would replace it. if you get it wrong you can over pressure you tank and it can explode
Jun 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
215 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
