The illustration appears to show a wire going to Power, a wire going to Tamper & a wire going to Alarm. I'm sure 1 wire will go to each power terminal. This is supposed to be a 4 wire device. Where do the other 2 wires go? Thanks
SOURCE: PIR Intruder alarm magnetic contact
Hi Bowdi,
Please find the below the information on the contacts.
You will fine two silver screws - This is your Alarm pair and this will go back to the alarm zone on the panel PCB.
The three other brass screws are just junction screws so you can join the cables to go to other doors.
You will need to join the black and blue together to make the tamper circuit.
Regards will
SOURCE: My Intellisense fg-730 glass break
http://www.cwasecurity.com.br/produtos/manuais/83_1237304479.pdf
Hi please find above your manual, in there is, should be all one needs to know...
And YES there is indeed a battery backup inside the unit, you need to get inside the unit to find and replace the battery, once inside it's all pretty obvious..
see below to for some info that may help?
http://www.diysecurityforum.com/index.php?action=printpage;topic=4195.0
