Question about Kenmore 15129 Built-in Dishwasher
Dishwasher installation problem
I have a kenmore MODEL: 22-15149, 587.1515, and am having trouble connecting the other end of the elbow pipe 3/8" to the fill line, one side fits into the dishwasher and the other seems too small to connect to the fill line. According to the user manual, I have all the parts needed to install so I am not sure why it is not fitting or seems to be too small. Help!
  • 68 Answers
They say that all parts are supplied. That means for the drain. They do not supply all the parts for the supply line.
I recommend a dishwasher suppy kit. It comes with:
  1. 3/8"compression x 3/8"compression x 48" flex line,
  2. 3/8" MIP x 3/8" compression ell,
  3. 2 adapters 1/2" FIP x 3/8" compression.
Install the dishwasher ell on the bottom of the dishwasher, connect the flex line to the ell, run through the hole in the back/bottom of the cabinet, connect to the supply line.
The adapters in the dishwasher supply kit should fit most connections under you sink. If by chance it does not, you may have to change the supply shut off under your sink.
Please rate this solution
Posted on Aug 19, 2008
I do not have a dishwasher now,but im having one installed ,will it come with all the parts needed to install it or will i have to get some , also what are they.
Posted on Jan 29, 2008
I have had this problem in the past as well. They state that you have all the parts you need to install the dishwasher, however that is assuming that it is under ideal conditions. You will need an adapter to attach to the fill line to make it match the size on the diswasher. They usually only cost about $3.00.
Posted on Nov 10, 2007
Why do soap suds remain in the bottom of my Kenmore, model #665.13113K701, dishwasher at the end of a cycle? I have run several cycles without soap and there still are suds remaining.
My guess being I have not physically seen it:
A.Improper install and the system is not draining properly.
B.Clogging in the drain pipe at the sink to the sewage system.
C.Failing draining pump.
D.Water softener issues.
E.Someone you have over is pranking you.
Aug 06, 2014 | Kenmore Dishwashers
The water will not drain after the wash and rinse cycle have ended. Serial # SR3701411 Model # 665.16034400 Cybe # 565-D
Why the Dishwasher Won't Drain?
In this section, we are trying to figure out all the possible causes behind the problem. We are also providing you with some solution to fix each one of those problems:
Reason#1: The most common reason behind improper draining of dishwasher is clogging of the household drain under the kitchen sink. Observe the dishwasher carefully while it is draining. If you find that water bubbles are coming up into the sink, then it is likely that the problem lies with the drain pipe and not the machine. Detach the drain pipe from the kitchen sink and clear out all the debris that are causing the clogging and reattach it. Also check the pipe that connects the dishwasher and the sink and remove if there is any trash left. Know more on unclog kitchen sink.
Reason#2: If the door latch of the dishwasher is not working properly, then the door cannot be closed and the dishwasher is not going to drain the water fully. Check out if the latch has become loose or gone out of alignment. In such cases, tightening the bolts of the latch will help in fixing the problem.
Reason#3: Accumulation of food particles in the dishwasher basket can prevent the water from flowing out of the drain. In that case, you have to disassemble the dishwasher basket and clean all its parts thoroughly to get rid of the gunk matter. Then reassemble the basket and you will find the drain is cleared. You can do this repair work on your own if you have some knowledge about the dishwasher parts. Take the help of user's manual provided by the manufacturer to find out the right technique to open the basket of the specific model that you have.
Reason#4: A new garbage disposal device can be responsible for this kind of trouble. This will happen if you have recently installed a garbage disposal and have not removed the knock out plug from it, then the dishwasher won't drain water. Once you remove the plug, it will ensure that the water from the dishwasher goes directly into the disposal for draining. Clogged garbage disposal can also trigger this type of trouble. Running the garbage disposal with plenty of hot water can clear such obstructions.
Other Reasons: In case all the above mentioned techniques fail to show desired results, then the defect could be something more serious and is related to some of the other parts of the dishwasher. Problems related to the drain valve, timer, belt, pump or motor and may require replacement with a new one. The part to be replaced has to be chosen very carefully and it should be right for the specific model that you have. It is better if you do not try to fix such things on your own and consult a repair professional who have the skills to handle these problems more effectively. You may even land up in trouble with the warranty of the appliance if you install any wrong part in your model. Know more ondishwasher not draining.
Now you are aware of the factors for which the dishwasher won't drain. After the troubleshooting, run some hot water thought the garbage disposal to clear any residue of dirt and grease from the pipes. Then start running the dishwasher. You can prevent such problems in future by running some vinegar through the dishwasher once or twice a month. If you live in an area where you get hard water, then clean the sink drain with a drain cleaner to keep it free from mineral deposits.
Oct 02, 2010 | Kenmore 24 in. 16034 Built-in Dishwasher
A Kenmore model 15522000 type 280-1 dishwasher will not drain
I scooped out the water and found a spoon jammed in the drain area. Works like a charm now.
Feb 04, 2010 | Kenmore Dishwashers
Connect water line and drain line
The supply line connects to the brass screw in fitting on the bottom left corner under the washer.
When you buy a dishwasher supply line kit, it will come with any adaptors needed. Unless you are using the steel braided line you will need to use teflon tape on the threads of the line. If you are using the SS line kit, you will only need tape on the adaptor.
Here is a pick of the line and the adaptor.
The drain line is attached with a typical hose clamp like this.
It is attached to the stub out on the garbage disposal if a GD is installed. If not then it is attached to the stub out on the drain pipe for the sink, like this.
Here is a pic of a drain line installed on a Garbage Disposal.
Oct 03, 2009 | Dishwashers
I have a leak in a 3 inch pvc straight section of
Add a U-bend to the pipe. You'll have to cut out the bad section, then add 90 elbows to each end. Then you can install the repair piece by slipping it into the two ends.
Jul 30, 2009 | Plumbing
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
Splendide Comb-o-matic 2000 how do you vent it to the outside
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting.
I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer.
After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent.
Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
Dec 26, 2008 | Splendide 2100 Vented Washer-Dryer
Tub shower combo... newly installed but leaks from shower head when turned on
Some shower heads require a rubber washer that would fit in the opening in the shower head. That may be all you need and would be the simplest fix. Check that first.
Sounds like you need some teflon tape available at any hardware store. The teflon tape should be wrapped around the pipe threads with 2 or 3 wraps and then screw the shower head on to the pipe. If the leak is in the wall, remove the shower head pipe from the wall pipe elbow and apply 2 or 3 wraps of teflon tape to the shower head pipe threads and reinstall to the elbow in the wall. You may need a pipe wrench if the pipe is real tight. Good Luck
Nov 30, 2008 | Dishwashers
Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Feb 16, 2008 | Dishwashers
Replace a dishwasher
Hopefully there's enough slack in your water supply hose for you to just pull out the machine and unscrew the hose.  Be sure to turn off the water before you unscrew it.  You might be able to unscrew the bottom plates to access the supply connection from the front.  Your new machine will probably have a 3/8" female connection.  I'd suggest having a 3/8" street elbow and an adapter for 3/8" male to whatever your plastic pipe.  The other thing to watch for is whether your machine is hardwired for electricity or has a cord and plug.  You can use your old cord and plug on the new machine, if the new one doesn't have one.
Oct 20, 2007 | Dishwashers
Kenmore 15129 Built-in Dishwasher Logo
449 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
