Make sure spark plug is tight,if that is not it pull plug and ground it to see if you have spark,also make sure plug is not fouled,then check ignition coil,that if there are two primary wires make sure there are connected and power is getting to them.if you have just one wire coil is internally ground check for insultion breakdown also make sure your plug wire is good
