Question about Sony Cyber-shot DSC-W55 Digital Camera
When the camera is turned on , the zoom tries to adjust twice while the displays says" access" then it Says" Turn the power offand on again" Following the instruction does not solve the problem, we can see the images if we press play.
  • kuezpallin Jul 01, 2009
    Found Solution Here
    http://www.digitalcamera-hq.com/digital-...
    Just had to firmly flick the bottom of the lence while it came out then just turned it off and on.
  • Sony Master
  • 586 Answers
The error "Turn off the power and on again" shows when the zoom motor start malfunction, If you want to repair by yourself and have experience then change the optical zoom motor it will reduce your cost. Otherwise you can change complete lens block assembly, both part and description is given below for your help and convenience:
Part No. Description
1-788-363-11 OPTICS UNIT (ED13A) (complete lens block assy)
2-673-648-01 ZOOM MOTOR UNIT
You can contact any expert or Sony Service Center to change the above said part and your camera work fine again.
Thanks for using fixya.
Posted on Jul 02, 2009
Icon very big how can i make it small
First of all try this: Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
If it doesn't help, follow the steps below and repeat the above (step 5.)
  1. Tap the "Settings" menu from the iPhone home screen.
  2. Tap "Accessibility."
  3. Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
  4. Return to the iPhone home screen.
  5. Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Apple iPhone 3G
Have a sony cyber- shot and out know while usign it the zoom started moving in and out on its own. now the camera turns on but just zooms in and out and then tells you to turn it off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
May 11, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony cybershot dsc w 55 - when the camera is turned on - the zoom tries to adjust twice while the disply says access - then it beeps and says turn the power off and on again - it doesn't work
Hi!
The focus is stuck. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony dsc-h1 locks up when zoom is adjusted
I actually have the exact same problem with the Sony Cyber-Shot DSC-H9 It says Access because it's strugglign to read the media card you have in it. Sometimes trying a different card works, but it likely needs hardware repair. mine is in the shop for the 2nd time with the same problem.
May 30, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
DSC S600 Won't stay on
i know this will sound really obvious, but i had the same problem a while back and changing the batteries fixed it
it might help
Jul 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
I can't zoom with my DSC-H1
Check the Sony Support site for this- it may be a free firmware adjustment to down load.
It is not likely an out of warrant camera could be a viable repair option
Feb 10, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony DSC-W30 ACCESS problem
try hitting it against something harder (like a table). I just did and it worked for me.
Jan 28, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
292 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
