Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
18 HP V tech B&S single is smoking only 4 years old
I change my oil and filter every 50 to 75 hrs. I have an old 10 HPthats at least 30 years old and only the oil 5 or 6 times.
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Posted on May 01, 2011
  • 80 Answers
The oil pump cover could be leaking it is in the crankcase cover and is held with 3 bolts in side contains the oil pump and an o ring the o ring could be worn and letting oil pass by allowing it to leak
Posted on Sep 07, 2012
Blowing white smoke out of exhaust
sounds like it is still overfilled ,, oil is leaking on the back side of the piston .. or may be a blown head gasket and being overfilled was just a coincidence if it is a briggs motor I would be suspect of a head gasket.
May 24, 2015 | Husqvarna YTH2042 42" 20 HP Lawn Tractor...
My 2007 GMC Yukon has 120,000 miles. Recently, I noticed that when driving the vehicle, the RPM do not drop, or reset, as the car accelerates. Instead, the faster the car goes, the higher the rpm's go,...
You have a failed transmission that will have to be
rebuilt or replaced with Reman
The flair in the rpm & gear change issues, should
have been the clue
How does that happen on a 7 year old vehicle ?
You fail to change your transmission & power steering
fluids every three years & those items that should last
15 years & 150,000 or possibly more, are given a death
sentence.
Trans fluid breaks down from heat in about two years &
like all fluids the additive packages are used up
Brake Fluid --every 2 years
Spark Plugs --every 3 years or they wear & stress the
ignition system
Motor Oil-well-you do as you please
I change mine 3 times a year,which is about 4,000
miles
When we worked-four times a year
I have a 2014 vehicle that I got in march
Changed the oil this Monday at 711 miles
WHY- it has been in there 4 months (remember
3 times a year) BUT --i keep my vehicles 18 years
I have one that I have had 30 years
The trans fluid --I will be doing soon
WHY- because I once owned a trans shop
& know what wears & when
Most wear,you ask-yep-the first thousand miles
& this vehicle has NO Filter,just a screen
Jul 25, 2014 | 2007 GMC Yukon
G'day, 1800cc n16 owners without a manual yet. needing to know the oil preference-- synthetic or mineral?,also the ideal change period and quantity, thankyou... were students again and quiet capable of...
depends upon the year of the vehicle, the newer the vehicle, the less tolerance in clearance of the parts that need the oil -- hence - synthetic oil is the better.,. otherwise, If you have an older year vehicle or otherwise a vehicle with high mileage, then just run with a good 10-30- or 10-40
for oil change again it would depend upon the year, my 2006 subaru is the same as the 2000 one I have -- 7,500 miles -- under normal conditions (low dust, etc) if you are in high dusty conditions, change oil and filter every 3,000 miles or take a peek at the color and smell of the oil (also keep an eye on the air filter as well..
Best regards
Ck
Mar 06, 2011 | Nissan Pulsar Cars & Trucks
Oil & gas ratio for an older Craftsman chainsaw?
Unless the saw is over 40 years old, 40:1 ratio will work well. Really old saws required 30/32:1 ratios when petroleum based oils were used. Be sure to premix the fuel and a modern synthetic saw oil in it's own can and be sure to shake thoroughly just before refueling each time. Check the H jet setting by warming the engine up, then pull the throttle full on. Proper adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Be sure to check the fuel filter, air cleaner and muffler for plugging before making any jet adjustment. Hope this helps!
Jun 26, 2010 | Garden
I want to connect a single phase 24 amp kiln under my waterproved pergola. What electrical work needs to be done and how much would it cost approxmatly?
That kiln requires a 30 amp circuit, minimum. 24 amps x 125%= 30 amps per National Electric Code (NEC).
Without more info, I'll need to make a few assumptions. For the sake of estimating the cost I'll present the following scenario:
1...The distance from your electric panel to the pergola is approximately 100 feet.
2...The circuit will be underground. I'll assume that you will be able to hire someone to dig an 18 inch deep trench from the electric panel to the pergoda for $10 hr. While this should only take 3 or 4 hrs, depending on soil conditions, it could take all day. So I'll assume $80 for this.
3...This will be a 240 volt, 30 amp circuit (see why below).
4...Since you posted under the Intermatic T171, and since that is a 120 volt timer, that the kiln is 120 volts.
5...Unless the pergoda is fully enclosed, NEC still requires a weatherproof installation.
For starters, I don't recommend a 120 volt kiln. Most people I've known who had a kiln always seemed to want a bigger one ;-) Again, I'll do the estimate for a 240 volt, 30 amp kiln, as the price difference compared to a 120 volt circuit is about the same.
Also, I strongly recommend using 3/4 inch PVC conduit as opposed to 1/2 inch PVC or UF (direct burial) cable. 3/4 inch conduit doesn't cost much more than 1/2 conduit and will allow you to install wire up to #6. UF cable, in my opinion, is out of the question because if you ever decide that you want a larger kiln the direct buried UF cable is _not_ easily replaceable. A conduit and wire installation is about the same price as UF anyway.
Here's the breakdown (US dollars):
$ 10 - 30 amp, 2-pole circuit breaker
120 - 300 feet of #10 THWN COPPER wire (40 cents a foot)
20 - 1 bundle (100 feet) 3/4 inch PVC conduit
10 - 3/4 inch PVC elbows, fittings, straps
20 - Weatherproof box and weatherproof cover
+15 - 30 amp receptacle
______
$195
+100 - 2 hrs labor @ $50 hr. (possibly 3 hrs.)
______
$295
+80 - labor for trench
______
$375
+140 - Intermatic T172R (weatherproof) 240 volt timer
______
$515
Other considerations are that, if indeed, the circuit is 100 feet, you should consider using a #8 THWN COPPER wire to account for voltage drop (add $60, @ 60 cents a foot) Using a #10 wire at that distance may not allow the kiln to get to the desired temperature.
If you are anticipating things like lights, 120 volt receptacles, fans and such, the best way to do all that is to install a subpanel at the pergoda.
That should get you in the ball park as far as price. Of course, you can make adjustments accordingly. Remember that prices can vary greatly depending upon geographic location. Also, if you call a contractor for an estimate, _after_ they give you the price, _then_ ask how much they will knock off if you dig the trench.
A contractor price of $600 would not be unreasonable.
Hope this helps.
Jun 02, 2010 | Electric Intermatic T171 24 HOURS 40 AMPS...
Lots of smoke and oil comming out the exaust . only 1 and a half year old
Has fuel with oil accidentally been mixed to the fuel for this mower? We have had mix oil accident get added it to this lawn mower and it will smoke a lot with 2 cycle oil.
Unless you are certain no oil is mixed with the fuel I would drain and clean the fuel system.
Replaced the spark plug with the new and replace the air filter In addition ensure you do and oil change every 30 hours using a high grade 30 wt oil to include make sure it is not over full.
Hope this tip helps.
r/
David
Feb 06, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Monitor 41 20 years old rebuilt 3 years ago. out of fuel
Hope you got this fixed. Sounds like you were having fuel flow problem.
Jan 17, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Honda 2750i Powerwasher
I had the same problem 3 years old, maybe used 10 times - removed the air filter and the washer started fine. The air filter looked fine - I have not tried to replace it or figure out the root cause. I was just happy to get it running again :)
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,551 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
