Question about Refrigerators
The drain line from the freezer for defrost water keep freezing
The drain line from the freezer for defrost water keeps freezing up and the water drips into the bottom refrigerator
  • aaron_drenno Jul 01, 2009
    Sorry, It is a Kenmmore top freezer and I think the model is 106.70282991. I have to empty the refrigerator and freezer and thaw out the drain tube quite often.
    New Friend:
GLRS267Z
Posted on Jan 22, 2016
    President:
  • 1,136 Answers
Hi, Could you get me a model # so I can look this up and give you instruction. Some models require an after market drain heater.
Vic
Posted on Jul 01, 2009
GE Side-by-side refrigerator defrost drain trough keeps freezing up. Drain tube is clear and never gets frozen but ice builds ups and overflows into the bottom of the freezer. What is causing this?
Sounds as if the defrosting timer or the heating element has gone out. Since the fridge works without problem off and on I would lean toward the heating element.
Mar 26, 2016 | GE Refrigerators
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
Sanyo side by side door fridge is not defrosting, what to do?
bonjour,
Trouble comes in 3's
If there is never any water in the drip pan under the refrigerator it is not defrosting and the evaporator drain line may be stopped up. Side by Side refrigerators cool the freezer first and send a small amount of cold air to the refrigerator side. To start defrost the defrost timer stops the compressor and all fans. Next it turns on the defrost heater. This melts the ice/frost off the freezer coils. The water drips down the drain line to the drain pan under the unit. If the defrost heater raises the temperature too high the defrost termination thermostat turns the heaters off. When the defrost timer finishes it turns off the heaters and turns the compressor and fans back on. If the drain line clogs with food the water does not drain out and when the compressor starts again the water freezes. If this keeps happening the ice gets higher and bigger until it clogs the coils and the freezer does not get cold. If the defrost termination thermostat turns off the defrost heaters too soon all the frost is not melted from the coils. And the coils soon clog and the freezer gets too warm. No defrost usually means either a bad defrost timer, a clogged drain line, a bad defrost termination thermostat or some combination of the three.
If the drain line is not stopped up you can try this.
Remove all food from freezer and refrigerator, open the doors and unplug the cord. Wait 30 hours for all the frost to melt.
Keep the doors open and the cord unplugged the whole time. Empty the drain pan to keep it from over flowing. After 30 hours plug it back in and wait for 1/2 cup of water to turn to ice in the freezer. Then you can put the food back in. The problem can return if the unit is not defrosting. Or you can call a service technician.
Jul 11, 2012 | Refrigerators
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Kenmore colspot freezer drain line keeps freezing
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 17, 2009 | Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Whirlpool refrigerator Model Number ET1FTTXKQ03 Keeps freezing
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 10, 2008 | Whirlpool ET9FHTXMQ Top Freezer...
Defrost Drain in Freezer is Freezing Shut
it totaly needs to be defrosted with the doors open for a couple days. the drain tube might be pluged with something else than ice. once defrosted poor some water down the drain to make sure its unpluged. dont for get to empty the pan!!!
Jan 16, 2008 | KitchenAid KTRC22EL Top Freezer...
Kenmore Coldsport freezer drain repeated freezes
probably the easiest fix for this is install a drain probe to transfer heat from the defrost heater into the drain hole to prevent ice build up. take a peice of 10 or 12 guage solid copper wire and wrap one end around the defrost heater pretty tight and put the other end down in the drain line 2-4 inches.
Dec 15, 2007 | Refrigerators
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
373 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
