Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
Black and white
I have connected my canopus converter to a macbook pro using RCA cables from a panasonic nv-hv62 vcr. It is a multi function VCR. I have connected the converter to the macbook pro via a 6 pin fire wire cable. It works except there is no color in the picture. I have switched the Dip switch 1 on the back from off to on and vice versa with no result. I have the dip switches in the default positions. I have played the tape through the TV and it works fine - I live in Australia and the TV is Pal.
My email is John at
  • baino1 Nov 09, 2007
    The television I used was the Sony HD Model # KDL40X2000
  • 4,102 Answers
This sounds like its a setting problem on your controll can you change the setting that says av try this its sounds like its not picking up the right signal check all wires are not damaged then try changing the settings in your menu options it is not a fault with the unti itself so dont worry to much as i dont have manuall for that model i cant tell you what settings to change ill have a look for manuall on net for you and will email if find anything what make and model of telly are you using ill email info to you if i find it sorry couldnt be any more help going to bed 10 past 1 in mornung here will look on net for manuall in morning hope this is some help to you sorry couldnt help tonight its late will email tomoz...............................................
Posted on Nov 09, 2007
I want to connect our VCR to the new Sharp HDTV,but I do not find audio,video out on the tv.How do I link the two?
Some HDTVs can output analog video and audio but if you say your HDTV does not, then you would have to use some other tuner/box/decoder/converter such as a cable box if you have cable TV service or a DTV converter box for over-the-air TV or a satellite box. The VCR would connect to the tuner/converter box and record analog video and audio using the RCA yellow video and white audio jacks. Standard VCRs cannot record high-def video except as down-converted analog video.
The VCR would then connect to the HDTVs inputs (yellow, white) for playback.
Mar 03, 2011 | RCA VR651HF VHS VCR
NV-VP60GC-S How do I get the color?
really? that's a settings up the menu(got a manual with this item?) and reset for defaults.
May 23, 2008 | Panasonic Multi-System Region-free...
NO. Your VCR is not stereo capable (white and red), it is only MONO (white) so only connect the white RCA plug to the white jack. Leave the red cable unconnected.
Jan 14, 2011 | Panasonic PV-7401 VHS VCR
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
I would like to convert a VHS tape to DVD. I have (1) the Sony Handycam Digital 8 DCR TRV310, (2) Panasonic VCR, and (3) Macbook Pro with iMovie. I don't know much about the digital camera's ability to...
I think you are expecting camera to covert VCR analog video-audio signal into digital so it can be record in Macbook?
Camcorder will not do this job and you need to hookup VCR with DVD Recorder to burn DVD of VHS tape.
Jan 07, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
Problem taping on vcr from panasonic nv-gs50
if you are using rca cables let the cam playing something you recorded and try find the channel on vcr(on its tuner).it would be helpfull if you post a picture of your cord
Nov 03, 2007 | Panasonic NV-GS50 Mini DV Digital...
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
248 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
