Question about HP OfficeJet t45 All-In-One InkJet Printer
Sending a fax
After upgrading to DSL the fax will not send.
  • armimi Nov 09, 2007
    Yes I do.
  • BabyChu Jun 30, 2008
    I cant receive nor sending fax and gives me a busy tone even all the lines are connected to my computer and all hooked up right...Why?
    Genius:
  • 1,601 Answers
Do you use the same phone number for fax and DSL?
Posted on Nov 09, 2007
  • Thomas Christopher
    Thomas Christopher Nov 09, 2007
    Do you have a splitter on the line? DSL wont work with one on.
Sending fax displays comm.error
There are many things that can interfere with proper sending of faxes. Has anything changed in your office recently? Phones changed? Did you recently get DSL service from your phone provider? If so, you probably need a DSL filter on the line going to your fax machine. Try faxing to different faxes to make sure that it is not the person you are sending to that has the problem. If you are using Voice Over IP or VOIP phone, good luck, as older fax modems do not always play nice and you will likley need to speak with your VOIP provider to ensure they have their lines configured. If nothing has changed in your office then perhaps your modem has just failed, it does happen. A new cord between the jack and the machine is a a cheap test as well. If you have a telephone, unplug the fax and plug in the phone and see if you can make a call.
Sep 04, 2014 | HP LaserJet 2840 All-In-One Printer
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Faxing with Dell printer 968
Firstly yes your telephone number is used as your Fax number.
Your phone line connections sound ok, so the problem must be with your fax machine.If it's a combined Fax/Printer make sure you select Fax mode.
Dec 05, 2008 | Office Equipment & Supplies
I have the lexmark 6500 andwhen i fax i keep getting a fax error message.
check and make sure you are not using a dsl filter on the fax line and your dsl is disabled when sending also check the fax send and recieve type
Sep 12, 2008 | Lexmark Office Equipment & Supplies
MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP OfficeJet t45 All-In-One InkJet Printer Logo
19 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
