I have a Frigidaire Affinty Front Load washing machine. Model Number ATF6000ES0. Recently it hasn't been working correctly. It wouldn't drain, which I have fixed in the past by taking it apart and cleaning out the drain. I did that this past weekend and it was majorly clogged. Cleaned it out, put it back together, tried to do a load of wash. It ran for about 10 minutes and then just shut itself off. I've been doing some research and have concluded it could be either the Door Lock Assembly or the Control Board. I know we have issues with the door latch because we have to hold the door shut when pressing start for it to lock. But it has ran fine for many months by doing this. This morning I ran an empty spin cycle just to drain all the water out. It started and ran completely through just fine. So now I am thinking it is the control board. I just want to somehow make sure this is the problem before I spend $150-$200 on a control board.
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
SOURCE: Washing Machine starts, squirts water, then stops.
E5E IS FOR Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
SOURCE: MAH5500BWW "LR" Motor Control Board Failure
By the time you have finished mucking about it will likely cost you much more than it would to have a Techo come out to give you a quote for a few dollars to see if it is all worth it as regards your budget!
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
