Question about Kenwood KFC-6982ie Car Mid-Range Speaker
Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
Will 2 KENWOOD KFC-6982iE speakers fit in the rear deck of a 1999 mazda protege?
  • 3 more comments
  • clutch30 Jul 01, 2009
    they are 6x9"
    500 w each
    depth: 3-1/16"
    crutchfield says they wont fit but i dont see why they wouldn't
    they are 6x9"
    500 w each
    depth: 3-1/16"
  • clutch30 Jul 02, 2009
    why wouldnt it sound good?
  • Jacob Blackwood
    Jacob Blackwood May 11, 2010
    Do you know the kenwood speaker size?
  • 93 Answers
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Posted on Jul 02, 2009
Trying to install kenwood kfc-1662s speakers in my 07 silverado crew cab and having problems mounting the speakers in. is there a mounting bracket that i need for them?
These speakers are not designed for your truck. I recomend asking chevy of what brands and what size speakers will fit in your truck.
May 15, 2011 | Kenwood Car Audio & Video
Replaced Headunit with after market one, but now the dash lights don't work, Fuses are fine, everything else is fine. Car is 1999 Mazda 323
Hi, there is a factory wire (red with a black stripe) in your car for illuminating the stock radio. This wire is not to be used in an aftermarket radio, so you need to make sure it isn't connected and also isolate and bare wire with electrical tape. Please let me know if you have questions, and thanks for using FixYa.
1999 Mazda Protege Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Yellow
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Yellow/Blue
Right Front Speaker Negative Wire (-): Violet/White
Car Audio Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Green/Orange
Right Rear Speaker Negative Wire (-): Green/Black
May 03, 2011 | 1999 Mazda Protege
Can i run a 4 channel 400watt amp to 4 6x9 speakers?
yes i dont see why not
they should work perfectly
is the question how to wire it?
if so then reply to this message
LOL
kenwood KFC
May 12, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
Ity might not be the best thing to do but if you dont care about waisting anymore money then give it a try..
Mar 21, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
Mazda protege rear strut replacement 02
they're underneath the plastic deck cover in the back, where the speakers are. -just a few plastic fasteners and the wire connector for the rear light, and it'll pop right off. -just did it myself this weekend
Jan 03, 2010 | 2002 Mazda Protege
Speaker addition
if i was you, i would make some speaker boxes that arent that fat, but will actually fit in the back window. otherwise, u could try to put 6x9 holes in the back below the window. but id try making some boxes
Dec 12, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Mazda protege 1999 rear brake replacement
Have you adjusted the adjuster to bring the shoes close to the drum? Always force the pistons in (the return springs should hold them in) and then adjust to make a tight fit after replacing. When the shoes are on right, there is no way for the piston to come out, as there is only a quarter inch of travel.
Jul 27, 2017 | 1999 Mazda Protege
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Radio Speakers
Its possible that some wires are loose, considering both rear speakers are not working and not just one. Your best bet is to check for any loose wires behind the front deck or behind the rear speakers.
Apr 15, 2009 | 2001 Mazda Protege
Kenwood KFC-6982ie Car Mid-Range Speaker Logo
149 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
