Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42in mower deck spindle breaks and Strips.
The Craftsman's 42in mower deck spindle breaks and strips out both the pulley and shaft all of the time. It costs me dearly in time and trouble to purchase, wait for the order and wrestle with the repair. Craftsman needs to address this problem if they want repeat business from me.
I would suggest a thicker tougher housing and thicker pulley which makes more surface contact with the spline or you could even use a standard slotted shear key. If you are worried about causing damage by putting too much shear stress on the mower housing, make it stronger too. You could also widen the span of the feet of the spindle and add more bolts.
    Scholar:
  • 138 Answers
There are thousands of these mowers out there, and most people do not have the problem that you are experiencing - let's face reality, you are hitting something, that's the only way these break - it is impractical to make a machine that will mow through rocks, stumps, and water pipes and not break - also, sears does not MAKE anything, they contract companies to make products for them - if you want a thicker, tougher mandrel housing, log onto www.amcpartsstore.com. they recently began offering a heavy duty version of the mandrel housing, part no. 130794. i've seen these and they are definitely beefy - just be sure to put everything together correctly and tighten all the nuts and bolts firmly, and try to avoid the rocks and stumps
Posted on Aug 26, 2009
    Problem Solver:
  • 19 Answers
Always remember: Part of the sale is eventually needing repair parts. Limited longevity is a key engineering component in order to sell parts. If everything lasted forever, factories would soon close down.
Posted on Apr 10, 2010
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
Remove mower spindle star is stripped blade moves
If star is actually stripped, you will have to replace the whole spindle assembly and blade. I would not change just the shaft if I was you as its almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade will not tighten star stripped on spindle
You will have to change the spindle and blade. I would replace the whole spindle assembly as just the shaft is almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to remove pulley from spindle to replace shaft on craftsman driving mower 42'' deck
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Sep 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I am having problems stripping the mandrel shafts and pulley, can any one tell me why, is this just a weak point or what?
Are you saying the pulley on top of the blade spindle is stripping out? If it has done it once and you did not replace the pulley and shaft, it will happen again. The shaft and the pulley are splined and if they gets loose, it will strip the splines from both. In other words, you have to replace the pulley and the shaft for it to work...and tighten them securely. If that doesn't answer your question, let me know. Dwain
Jun 15, 2009 | Craftsman Garden
Replacing parts on mower deck
I did sign up for the preminum plan but got no response.
Jun 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
908 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
