Question about Makita 7 1/4" Circular Saw 5007NB
Makita Circular saw 5007NB, the cutting depth guide is jammed. What can I do?
  • 2,176 Answers
You can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
Posted on Jul 01, 2009
Can I use makita 5007nb circular saw on 220vAC.?
i assume it will overheat and burn up at 220 volts. its not made for that. make up an outlet with one hot and a neutral off the 220 line
Feb 17, 2018 | Makita Saws
Replacing 5007 baseplate
I hope we're talking about the same nut, is it the one on the lever to lock the cutting depth? If so, it's held in place by a lock plate that you remove by taking out the small pan head screw next to the nut. After you take the lock plate off the nut should come off easily.
May 22, 2012 | Makita 7 1/4" Circular Saw 5007NB
How do you remove the brushes makita 5007nb saw
Just remove the brush caps. You may need to use a small pick or needle to pop the brushes out. In this diagram reference number 14 is the brush cap. They are just like a screw so you need to turn them to the left (counter clockwise) to remove them.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/5007NB
Jul 05, 2011 | Makita 7 1/4" Circular Saw 5007NB
My cutting depth lever will not tighten. How can I adjust it?
on the lever there is a circlip that you remove and remove the lever, tighten the hex nut with the lever until it holds in place and reassemble in the reverse order. Also you might want to check the carriage bolt to ensure not rounded or the shoe bracket is not spread allowing the bolt to turn instead of locking the shoe. Let me know if you need more assistance
Mar 23, 2011 | Makita 7 1/4" Circular Saw 5007NB
Instructions or diagrams on how to replace a power cord for a makita circular saw.
here's a article on how to fix it.
http://www.amazines.com/Electronics/article_detail.cfm/78565?articleid=78565
May 05, 2010 | Makita 7 1/4" Circular Saw 5007NB
I have a Makita sr 1800 circular saw. How do you
that is the standard circular saw with stationary shoe you cannot really set a depth in that model.l
Nov 29, 2009 | Electrical Supplies
Cord replacement on skill saw model # 5007nb
the cord set you need is 664463-0, the wire guage is 2x14x8 SJ any repair shop should be able to help you with the proper wire guage cord for this tool. The installation is really easy after removing the handle half
Nov 05, 2009 | Makita 7 1/4" Circular Saw 5007NB
45 degree cut
loosen the miter lock, tilt the table to 45 deg. tighten the miter lock
Feb 19, 2009 | Makita 7 1/4" Circular Saw 5007NB
Makita 7 1/4" Circular Saw 5007NB Logo
306 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
