Question about Poulan Pro Chain Saw 46cc 20"
Throttle linkage for Poulan 1950le
Which end goes to the carb, tried both ends still can't get it connected. It seems simple enough but can't get it hooked up. It came off while replacing gas lines.
  • waynezulu Jul 02, 2009
    I got it fixed , thanks
    Sergeant:
  • 384 Answers
Most times the thottle wire end is "Z' shape. The end of the wire is passed thru the carburator throttle lever untill the wire is past the first bend, the wire is laid over so that the travel of the wire is parallel to the swing of the throttle lever. Many times both end of the wire are the same or one end has a taller mid section to fit thru the hole in the plastic (if it's plastic) hand throttle end.
Posted on Jul 01, 2009
My poulan chainsaw 3416 has a throttle that is stuck/locked in the run position and also the choke will not stay pulled out ?
The throttle is a simple plastic lever that moves a rod bent in a weird configuration to align and connect to the carbuetor's shaft. Turn the saw upside down and look under the end of the handle, there should be a cap screw, either phillips, allen or torx that releases the back of the handle. Lift it gently and remove the other end from the plastic clips that secure it. Under there you will see the problem...either jammed with debris or just jammed up period. The choke should be a simple plastic affair whose issue could be related to the throttle linkage interfering with its operation. Solve the easiest first then look at the other problem.
Jan 19, 2015 | Poulan Garden
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Craftsman schematic
Most are pretty simple the carb linkage should have a small moon shaped disc with three or four small adjustment holes for the bent tip of the throttle cable. After attaching the cable to the handle and snaking it to the carb. There is a small clamp that will hold the cable in the adjusted position .slide the end under the clamp and then connect to one of the holes on the linkage..slightly tighten the clamp and slowly move the handle unti the handle goes the full travel..then check to see it the carb linkage goes to full throttle and backs off to idle..if it does not..loosen the clamp and keep adjusting to get the desired full throttle and idle..May have to play with it a couple of times but it will adjust..good luck..
Jul 23, 2014 | Craftsman Garden
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
How to hook up governor spring and throttle linkage on a briggs and stratton 8hp
From the governor 'vane', on end with a small hole in it is for one end of the spring........the other end of the spring goes to the throttle arm on the carb. YOU MUST HAVE THE CORRECT SPRING WITH THE PROPER LENGTH AND TENSION!!!
Sep 21, 2013 | Garden
Connecting carburetor to the throttle on husqvarna 44 chainsaw
The wire linkage has a short Z bend in one end this hooks into the throttle lever from the outside, the other end has a long loop this goes into the trigger arm from the outside, you will need to twist the top of the trigger arm slightly to allow the linkage to go into the hole in the trigger arm.
Dec 29, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Can,t find the spigot on which to reattach the clear plastic fuel line which got accidentally pulled off on my nearly new Poulin Woodshark saw.
What end was pulled off.The end to the fuel tank goes into a small hole.The other end goes to carb. but sometimes it is difficult to see.Its easiest to take out the screws holding the carb and lift it enough to find the fitting.
Oct 19, 2010 | Poulan Garden
Need exploded view of carb n governor linkage n spring location
the govenor spring fits in with the throttle linkage and the other end goes in the govenor...good luck
Nov 07, 2009 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
166 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
