Question about Canon BJC 80 InkJet Printer
Canon bcj-80 prints blank pages
I have cleaned the printer head, changed the printer head, changed ink cartridges 3 times, Any Ideas???
This printer is attached to a sonogram machine. It is the only printer that will work on it. They are pretty expensive for older models. Cant afford to replace it! I bought a refurb unit, it does the same thing, It worked for a month then the blank page thing started.HELP PLEASE!
    President:
  • 2,306 Answers
The problem comes mostly from the printhead. It helps to put a drop of water on the cleaning pad over to the right where the printhead parks, before doing a clean cycle.
Posted on Jul 01, 2009
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon BJC 80 prints blank pages!!
i think u already solved your problem...your printer's problem is its printer head...u cannot solve this problem by fixing it yourself.all u can do is to buy new printer head at printer's shop. it is true because i got the same problem with my BJC 200.i do the same solution as u r and lastly, i go to the technician and he said i need to replace my printer head at some price.....just think bout money n i discover that buy a new one is better(as for my problem)
not to discourage u, but try to plan either to buy new printer head or buy a new printer....
hope this solution help... ; )
May 26, 2009 | Canon BJC 80 InkJet Printer
Power off the printer.
Unplug it, then plug it back in.
Wait until it stops its initialization sequence.
Press and hold the power button.
Allow the printer to beep 7 times, then release the power button.
This will reset the EEProm to factory default, and should clear your problem.
I have a canon multi pass f80 printer. it is several years old (10?) i love it and have had NO problems. last night i went to print and my black ink has a new cartridge and there is no ink coming out...i...
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
May 16, 2009 | Canon MultiPASS F80 All-In-One InkJet...
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
178 people viewed this question
old marine
old marine
