Question about Frigidaire Freezer 16.7 cu. ft. Upright Freezer
I have a Frigidaire Freezer (Model:LFFU1465DW6) that is not cooling. I put 134A in it and it still doesn't cool. The compressor keeps kicking on and off. What's up? Also, on the sticker by the compressor says 134A 128 gr's. What does that mean?
3 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
  • 185 Answers
SOURCE: compressor kicking on and off. freezer not
If you have 120v coming out off the outlet and it is kicking on and off change the relay and the overload. if it has a capacitor change that to
Posted on Apr 04, 2010
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Why does my upright freezer runs then kicks off, runs then kicks off?
Good Afternoon Friend,
I understand your Frigidaire freezer runs for a short time and then kicks off. Then it turns on with a click and repeats its cycle. This is how your freezer functions. When it needs to cool, the compressor will kick on and cool until the temperature is reached. Then it will kick off until it needs to cool again. It's possibly due to the hot and humid summer that it is cycling on and of more. I hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Where can i find the repair manual for frigidaire freezer model lffu1465dw6
Good Afternoon Gene, thank you for your question! I understand you are seeking a repair manual on your Frigidaire freezer, LFFU1465DW6. I have located the Owner's Guide, Wiring Diagram and Parts Manual on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Aug 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire 20 cu ft. upright freezer went out a few days ago. Discovered bottom seal was not in place but fixed that. Alarm light stayed on through the night and freezer is not cooling AT ALL although...
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Aug 08, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Freezer won't kick on
That is the overload protector on the compressor. Keep the door closed to preserve the cooling you have from the frozen food. Leave it unplugged for about an hour. Bang on the compressor with a rubber or wooden hammer then plug it back in. If it does not start you either need a new start relay or a compressor.
Apr 15, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
It doesn
switch problem in engine or try bring to nearest service center
Apr 03, 2010 | Frigidaire Freezer Refrigeration White...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Freezer Problem
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezers Logo
324 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
