My camera was completely dead and would not charge and the lens would not close. i purchased a new battery and tried charging it. the charge light went on for a short period of time and the lens closed. now nothing works - i cannot turn it on and no light comes on - zippo. i don't think it's worth have serviced but i sure wish it worked because the battery was $30 - any suggestion?
SOURCE: my nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
SOURCE: Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
SOURCE: My camera worked fine one day, then it was in my
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
SOURCE: Nikon S200 Lens stuck inside
I had the same issue with my S210, so after reading other people's advice to send it in to Nikon and since that was going to probably cost me as much as the camera itself I figured it wouldn't hurt to try a little something. The lens on mine was a hair off center or had been pushed in on one side (barely - looking at yours you may be able to tell which side) - mine was in my purse also. So, I took my handy dandy skinny prying instrument (normal kitchen butter knife) took the battery out to make it try to open again, then when I popped the battery in as the lens tried to push out I pried the side I thought was a little lower back towards center...I heard a little pop and it worked! The lens came all of the way out and it's all good.
So, use gentle hands and try if you want, but don't think I warranty this!
SOURCE: Nikon D60 won't turn on and the battery is
Usually, when your battery has been in the charger long enough for it to be fully charged, the indicator light either changes color, or turns off. This indicates that the charge is complete.
Does your light do either, change color or turn off?
If neither of these works right, check your user manual, usually in the back, which will tell you what the indicator lights mean.
If your camera and battery are doing what they are supposed to be doing, then you may have bought a faulty camera, or the battery which came with it was faulty.
Be certain to read the manual very carefully, to be certain that you are following the instructions properly. If you have done everything right, then return the camera and or battery to the place from which you purchased the camera, and have them check it out to ensure that all is proper.
Hi cc longfield, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? How long did you charge the new battery for ? New batteries can sometimes take significantly longer to charge up the first time than batteries that have been through the charge/discharge cycle a few times, especially if the battery has not stored charge for sometime. Other possibilities include the new battery was duff (discuss with supplier, maybe if you returned the battery they would send a second new one) or that it's not a battery fault at all. These are just a few ideas which you have probably already thought of. You could investigate the camera's power inputs in a few ways
21.August.2014
