Question about Refrigerators
I have a Philco refrigerator model #F1112 that was probably bought new around 1945. It worked great as an extra until the power cord rotted through. There is a flat, 3-wire undividually shielded cord that runs from the top rear sealed compartment to the wiring block at the bottom where the power cord connects. The middle wire of the 3-wire connects directly to one of the 2 power cord wires. I need a diagram for the worong. Any ideas?
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
Illeagle
  • 525 Answers
SOURCE: I have a maytag dryer
A 4 wire cord should be hooked up accordingly:
1. Black wire to either outside terminal post.
2. Red wire to the remaining outside terminal post.
3. White wire to the center terminal post.
4. Green wire to the frame screw.
Also, make certain that your breaker/fuse box is wired according to local codes. If your dryer is not properly grounded through the fuse box and the green wire is attached to the frame then, a ground wire would need to attach to the green wire and then to an earth ground. This could possibly be your 5th wire, but you need to investigate it before applying power to the dryer.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
  • 4234 Answers
SOURCE: New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Thanks,
Dan
Posted on Nov 13, 2008
TheMobilian
  • 8220 Answers
SOURCE: I need a schematic for a Maytag Elec Dryer HDE606
Man I been digging around in the shop for my copy of a DE606 manual I have to no avail. hell I might have even thrown it away.
Well you have a common wire, a start wire,a run wire and 2 larger wires which carry the heater load. go with the 2 larger wires on those terminals for the cent switch. White would be common so that leaves 2 to guess at seems to me those might match number for number. Just guessing cause I ain't worked on one of these halo of heat models in years.
Posted on Jan 13, 2009
Fridge doesn`t cool
Return it to the store, especially if less than 30 days old (new)?? If used, it may need freon. Does motor run??
Mar 06, 2014 | Refrigerators
Need a power cord for Philco turntable 12 V 1000 Amps
Just choose a power cord of good quality. That is all.
Jun 09, 2012 | Philco Audio Players & Recorders
Where can I buy a power cord for HP Laserjet 4200n?
This device takes a standard computer power cable. You can purchase one here: http://www.newegg.com/Product/Product.aspx?Item=N82E16812339139&cm_re=power_cord-_-12-339-139-_-Product
You can probably find an extra one around the office if you look around, though. Grab the cables from old computers or monitors that have been thrown out.
Good luck.
Mar 02, 2011 | HP Office Equipment & Supplies
The refrigerator section does not cool well enough and food is rotting. Unit is around twenty years old minimum. Should I buy anew one or replace parts which was estimated at $4500?
Get a new one. Depending on the size you want, a new refrigerator will be cheaper and be much more efficient (energy usage) for the size. (Please note I'm assuming it is a household fridge ~25 cubic feet or less.)
(I have no idea on the prices for commercial refrigerators but the energy efficiency for the same size will also be greatly improved.)
Jul 22, 2010 | Refrigerators
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Jan 06, 2009 | LG Phenom Express
Power supply
This unit takes a 12V 0.5A DC power supply. Your local Radio Shack sells this type of supply that will plug into the wall. You'll need to make sure that the other end will plug into the turntable, but for the supply, Radio Shack is probably the quickest way.
Jul 24, 2008 | Philco PC-841.651 Turntable
Power cord not working
If your power cord plugs in to the back of the monitor, then you can find one just about anywhere that computer stuff is sold, like Radio Shack and Wal-Mart. You might be able to be able to get one free from a locally owned computer repair place as they most likely have extras lying around. Doesn't hurt to call and tell them you need one. If you have to buy one, they aren't expensive, usually 5 or $10. Please let me know how it turns out!
Dec 29, 2006 | Balance CM2017 17" Monitor
Refrigerators Logo
976 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
