Question about HP Scanjet 4470c Flatbed Scanner
4470c scanner when i scann i get multi color strips all up and down the page any ideas why????
  • 11 more comments
  • streak Nov 11, 2007
    4470c giving mainly yellow and red vertical stripes at left and right margins. Thickness of stripes varies from one scan to the next. Glass cleaning has no effect. Same problem when on different PC's, one at Precision Pro V3.14 the other at V3.12 so not a driver problem n.
  • scottbar Nov 12, 2007
    horizontal lines multicolors
    even after descreening still the same
  • VRRN Nov 14, 2007
    I am also having a problem with my 4470C scanner. I was scanning slides which used to work great & now I'm getting rainbow colored strips through the slides when saving or printing them. Also when I scan & print black & white documents I get vertical lines on the entire page. I tried descreening & it did not work to fix the problem.
  • Jaap Stengs Nov 15, 2007
    When scanning colour I get red horizontal lines.
    Using the MOIRé cure does not work.
    Now what,
    Jaap
  • SJ Johnson Jan 24, 2008
    4470c used to scan great, now get multicolor horizontal lines. descreening and adjusting highlights does not work. Any ideas?
  • Anonymous Apr 13, 2008
    horizontal banding on scanned images
  • calabogie May 10, 2008
    colored vertical stipes in scanned document left side
  • Anonymous May 19, 2008
    I have horizontal stripes through my photos when I scan. I tried your suggestion to use the descreening but without any success.
    Jajo
  • gtfossum Jun 25, 2008
    Not much happening here. Have the same problem. Horizontal lines whatever the scanningmethod. Descreening not solving the problem. It may be coincidental, but my problem appeared when moving from an old Pentium somthing to a new Dell D820.
  • Rodney Anderson Jul 28, 2008
    Scanning color slides results in colored horizontal lines.  Descreening option is not available.
  • Anonymous Nov 06, 2008
    Scan gives horizontal lines of blue, green, red, etc instead of other colors, all except white. White stays white.
  • tejnacs Jan 21, 2009
    MY Hp 4470c used to scan great 35mm slides. Running windows 98 ( don't laugh ). Lately I get multi-colored horizontal lines through the scanned photos. I uninstalled and reinstalled soft ware. This didn't help.
    Please help...
  • gtfossum May 11, 2010
    Descreening helps a little, but it does not by far remove the stripes!!! Several people have this problem, tries descreening and it does not help. There must be a better solution or explanation!
  • 3 Answers
Jaap's answer fixed the re horizontal stripes from scanning flat paper, but I now have horizontal lines, lighter and darker, when scanning slides. Any ideas?
Posted on Feb 12, 2008
  • demam Oct 26, 2008
    scanning slides does not allow descreening option. Any others ideas. The banding is quite severe. I have the latest drivers.
    dougalco
Re. hp scanjet 4470c.
Setting ADVANCED/SCREENING ON removes red horizontal stripes from colour scans.
My computer and scanner are in use allday, every day.
Capt. Jaap Stengs ret.
Posted on Dec 30, 2007
    Genius:
  • 1,601 Answers
  • Thomas Christopher
    Thomas Christopher Nov 11, 2007
    Did this work?
    Please post an answer so we can help you further.
    If it worked please rate this post as solved.
    Thanks,
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
Hi! I need driver for HP 4470c for Windows7 Please Help!
Hi ,
I succeeded to run my Scanjet 4470c under w7 32-bit Ultimate this way :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekature , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
Regards.
Nov 05, 2010 | HP Scanjet 4470c Flatbed Scanner
I need Windows Vista drivers for scanner hp 4470c. The support product of HP does not have it. Thanks
I checked the HP website - probably just like you did. They do not have drivers for the Scanjet 4470c. Looks like time to get a new scanner... You can list the current model on craigslist - maybe someone would be interested in it themselves.
Sep 23, 2010 | HP Scanjet 4470c Flatbed Scanner
When I shut down my computer my hp 4470c scanner switches on and the power button is unable to switch it off
There could be several reasons for this issue . It is not recommanded to leave hard drive connected to power when not in use . You should pull of the power plug after shutting down your pc and give it another try after reboot .
Maybe you have updated your OS and there are no more drivers available , like with Vista or W7 .
Try also by deleting driver in Device Manager and software in Control Pannel \ programs . Unplug device , reboot , reinstall sofware driver , reboot , wait for OS to be settled , connect scanner and wait for confirmation of successfull operation .
Regards
Aug 05, 2010 | HP Scanjet 4470c Flatbed Scanner
HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
Nov 10, 2009 | HP Scanjet 4470c Flatbed Scanner
4470c
If you can get the software on your computer, right click properties and check run in XP mode
Aug 28, 2008 | HP Scanjet 4470c Flatbed Scanner
Scanning 35 mm slides
SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
HP Scanjet 4470c Flatbed Scanner Logo
960 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
