Question about Rainbow 75th Anniversary Canister Vacuum
Vacuuming a small rug and it got sucked up a bit and now my extension won't work.
  • 11 Answers
Make sure the little red reset button is pushed in on the power nozzle.
Posted on Jul 03, 2009
    Sergeant:
  • 353 Answers
Belt burnt, replace belt
Posted on Jul 01, 2009
I have a huge area rug, I cannot even push the vacuum because it sucks up the rug. what can I do?
This vacuum is not made for the new soft carpets
only special vacuums are recommended by the rug Manf, Emer Vacuums USA
Here is a link for these vacuums
Jun 28, 2015 | Dyson DC28 Animal Bagless Upright Vacuum
Suction when vacuuming
Some vacuums have a valve or collar near the handle that you can twist to adjust the amount of suction on the vacuum. If you open it a little it will stop sucking up your throw rugs. IF the problem is not enough vacuum then the HEPA filter may be clogged. It's usually a rectangular filter in a plastic frame. That has to be changed occasionally or the suction of the vacuum will continue to drop off.
Apr 04, 2015 | Vacuums
Why am I unable to push vacuum forward on new area rug. But will work pulling backward. Works fine on old rugs and floor
It might be that the new rug has a backing that is not as stiff a the other rugs which can cause a rug to bunch up making it hard to push the vacuum forward.
Feb 23, 2015 | Dyson DC25 Animal Upright Ball Bagless...
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Belt keeps breaking after only short use on vacum cleaner
Each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn. The belt must be installed according to manufacturer directions for best performance, or the belt will chafe against the interior housing parts and break prematurely.Sharp debris, a low height adjustment setting or vacuuming up rug corners may cause the rubber belt to snap or wear prematurely. Check the height adjustment for the vacuum, and use a higher setting for plush rugs. Avoid vacuuming sharp objects and corners of the rug.
Jul 27, 2011 | Vacuums
Belt needs fixed after sucking up a soft rug.
if its a canister model there probably is no belt just suction.open the canister and if it has a bag feel the bag ,if it feels kind of hard then the bag is full.take the tool off the end of the hose and turn it on to see if you have suction if you do then the tool is blocked up.take it to the sink and run some warm water through it and maybe use a little brush to clear out the dirt.full bag will cause your vacuum not to have suction or not as much as it should
Apr 09, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Kirby g 5 head bounces when vacuuming and tech drive is engaged, does not do this everytime
first change the belt, even if it is not broken. also make sure that the height adjustment is raised up high enough, the higher the better ( when adjusting a vacuum you want the tips of the brush roller touching the tips of the carpet fibers ) also the same problem could occur on an area rug or any place the carpet is not securely held down ( the carpet can lift up and get sucked up into the vacuum )
Sep 22, 2008 | Vacuums
Rainbow 75th Anniversary Canister Vacuum Logo
170 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
