i got the router yesterday, at first 192.168.1.1 , the ip was working. later on it started not working at all. so i cant set up the router and use the internet connection. I tried to change my ip,default gateway,dns but none of them solved the problem. if anyone helps me,i'll be glad. thank you
17 Other Users Have The Same Problem
Comment by Guest, posted on Jul 26, 2008
on off switch not going green as in set up afterset up note error 106
Comment by smhohn01, posted on Jul 23, 2008
cannot connect to internet.
Comment by Guest, posted on Jul 18, 2008
speed of my internet is 10
Comment by ugenmano, posted on Jul 16, 2008
i can"t connect to 192.168.1.1.!
Comment by Guest, posted on Jul 16, 2008
i seen this on an forum which might be of some use.
riz.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
tom9
Rank:
ApprenticeRating: 91%, 10 votes
there should be a button on the bottom of the router labeled 'reset'
push it in and the router will reset to factory settings.
( dhcp is usually enabled by default)
the lights for network activity should blink for a few seconds as the
router gets a new ip from the network. you should then
be able to go to 192.168.1.1
and access the router.
some motorola routers use an address in the 10.x.x.x
range
range
Post a New problem for Gateway Wireless-B Router
Email this problem
Can you Help with these Routers problems?
Cannot connect to DING! or...
17 Other Users Have The Same Problem - Continued
Comment by ranjeet9161, posted on Jun 27, 2008
i canno acesss the same page plus the modem of broad band modet UTstarcomWA3004G4 that i have does reconfugure. however i am connected through same modem
thanks
Comment by Guest, posted on Jun 18, 2008
not open window Router Vigor 2700
Comment by quiltqueen, posted on Jun 17, 2008
same problem. can't get 192.168.1.1 to work. my printer caused my internet to crash. I can bring up the online computer by plugging the internet directly but I can not get my router to work. thought I would check 192.168.1.1 but i can not access it. please help i would like to go wire.less again. THANKS
Comment by Jones_jona, posted on Jun 06, 2008
i also can't find my 192.168.1.1 it just say the page not excist
Comment by Guest, posted on Jun 06, 2008
i got the same problem it cant find my 192.168.1.1 so if you can help me please answer .. :D
Comment by pradipt, posted on May 26, 2008
as solution for this problem is to press the reset switch but boss there is no reset switch in BSNL Broadband router Siemens SL2_141 (Type-B). for this what to do.....
please guide me........ very urgent
Comment by Guest, posted on Apr 25, 2008
I have the same prob.
sometimes when using 192.168.1.1 , the Router cant found.
I cant connect to the Internet using Linksys,because it is already had a s a connect and disconnect sign appears .
Comment by ogee, posted on Apr 23, 2008
i want to configure my IP but the server could not be found
Comment by picdev, posted on Apr 02, 2008
hi i need to setup wap on my rouyer so my printer will work
Comment by Guest, posted on Mar 21, 2008
my wireless router stopped working with my laptop
Comment by Guest, posted on Mar 13, 2008
عندى مشكله فى النت مش فهمها
Comment by Guest, posted on Dec 30, 2007
i changed my password and 192.168.1.1 refuse recognize my password ?
