Question about Whirlpool LER4634J Electric Dryer
Dryer not working at all
Whirlpool dryer model number LER5848EQ2, will not start when I press the start button, I have checked the circut breaker and it is plugged in, I set the timer and nothing happens. No sound, nothing. I've checked the belt and its on.
    President:
  • 1,136 Answers
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on Jul 01, 2009
  • Oscar A. LEBron Dec 12, 2012
    Wherer exactly would the back panel that you are referring is located?
My GE Dryer just stopped working. The washer is working, I've checked the circut breaker and the GFI breaker and they're all working. Is there a reset button?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2010 | GE DWSR483EBWW Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 | Dryers
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Sep 07, 2008 | Whirlpool LER4634J Electric Dryer
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
193 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
