Question about GE Lands Phones
On incoming call,rings once then disconnects .dosen't ring at phone
    President:
  • 1,952 Answers
Reset the ring setting
Posted on Jul 01, 2009
I have a mobiwire cell phone and need to know how to change the ring tone please?
Find "Customize"
Press the Navigation key.
Select Profiles.
Highlight General.
Press the Left selection key.
Select Customize.
Select ring tone
Highlight the field below "Incoming call".
Highlight the required ring tones to hear them.
Once you've found a ring tone you like, press the Navigation key.
Return to the home screen
Press Disconnect to return to the home screen.
Sep 26, 2017 | Cell Phones
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
Phone only rings once
ring tune setup ringing not beep or ring once
Jul 18, 2009 | Panasonic KX-TG5632M Twin Cordless Phone
Incoming calls briefly ring once then automatically kick over to answering machine. I cannot get any incoming calls
Are you using norstar voicemail system?
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
Jun 26, 2009 | NorStar M7208 Corded Phone
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Incoming calls to office cause all phones to ring in classrooms
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Lands Phones Logo
254 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
