Question about Sanyo DS35510 35" TV
Tv trouble Our T.V. does not display a picture through the cable connector, however it will show when a DVD is played through the Line 1 or 2 slots. Sometimes it makes a loud crack sound after it has been on for about 5 to 10 minutes, not on a regular basis. A VCR tape will not play either through the cable connector.Thanks
    Scholar:
  • 135 Answers
Hi there!
I think you may have a problem on the tuner module. If using scart connector in your country, check the cable itself or replace, otherwise loose connections on the inside of the unit or a circuit fault. Try the cable first then a repair technician. Good Luck,JUS004
Posted on Mar 05, 2008
DVD player won't show the picture and says F750 on display what should I do To unblocked it?
DVD player won't show video ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities
AppleHi sany42 welcome to the forums. You don't say which MacBook Pro you are using. Which graphic chip is running? Do you use third party software to manage ...
DVD Player not showing picture. ' MacRumors Forums
forums.macrumors.com > Macs > Mac Apps and Mac App Store
May 1, 2010 - Hey everyone, My DVD player application is not showing the picture. ...wttheninja said: ? ... So it seems DVD Player won't show a picture when my macbook pro is connected to my 30" Dell monitor via display port cable.
Mac's DVD Player won't show the image? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Dec 29, 2010 - When I put a DVD in my computer, DVD Player starts up and the DVD starts ... I can select things on the main menu, but the picture isn't showing.
db:: 3.91::Blu-ray player does not show picture ca - Hivmr
www.hivmr.com/db/jmcpaz9zsspf7s3m9zxfcs3383kma1sk
Still blu ray does not play says, Blu ray not set to region, but could play other blu rays from ... DB:3.66:I Just Brought Blu-Ray Disc/Dvd Player (Bdp-Bx59). ...... Help Request: My Blue Ray Disk Player won't "play", once the main show was to start. ....DB:3.36: How Do I Watch 3d Blu Ray Movies On Qosmio F750-1013x? 33.
Jan 19, 2016 | Televison & Video
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    TV HAS SOUND BUT WONT DISPLAY CHANNEL PICTURE, WILL SHOW MENU SCREEN AND PLAY DVD'S.
    Sir if you are using a digital receiver try to check the cables at the back of your tv the input and output cables, this trouble sometimes caused by a weak or loosed connection. Feel free to send feed back good day and best regards.
    Sep 13, 2011 | RCA Televison & Video
    White screen and black vertical lines over half of la26b450 model tv screen
    Good day!
    that problem is on the cable please try to play dvd or recorded tv shows.
    if you play dvd or recorded shows and picture is normal
    try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
    thank you
    May 29, 2011 | Televison & Video
    Picture is not on the screen. I cannot seem to
    Alot of times you have to back up the TV to something like LINE 1 or LINE 2. It will not show up with the TV on channel 3. When I attached my VCR, I hit input and line 1 and 2 came up and then the DVD player would play just fine. Try that.
    Jul 18, 2009 | GoVideo Go Video DVD/VCR Combo
    DVD-CD player
    hi sammiell try get a different cable for ur dvd n make sure the yellow cable goes to the yellow connector of ur tv.
    raj..
    May 17, 2008 | Emerson EWD7004 DVD Player
    No picture on screen
    looks like you need a new player, but first try anothere t.v if it does the same then you need a new player
    Oct 03, 2017 | Blaupunkt DVD-MER
    Color problem
    is there a speaker ( other than built in ) near the tv? ( if so, move speaker away from tv.
    Dec 13, 2007 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
    Sanyo DS35510 35" TV Logo
    94 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
