Question about Sanyo DS32224 TV
Sanyo TV Model# DS32224
The picture on the tv is bigger than the screen, seems like it is zoomed in
    Genius:
  • Sanyo Master
  • 1,689 Answers
This is usualy because there is either a high voltage regulation fault, or a main power supply regulation fault.
There are many things that can cause this. When the high voltage goes too far down, the raster will enlarge. High voltage regulation can be caused by faulty components in the feedback sensing, or in the high voltage multiplier, or in the flyback windings itself.
A quick way to sort of know if the high voltage is regulating is to wind the brightness and contrast from one extreme to another and observe the raster size. If the raster is changing size with the brightness on the screen, the regulation is not working well. In some of the low cost sets there will be about a 2 to 5% raster size shift in this case. The high end sets will have a near 0% shift in the raster size. A size change of about 2% is acceptable for most sets. If the CRT is weak, this test will not work well, because a weak CRT will not properly load.
If the main power supply is operating slightly over voltage, the raster size will increase. Usualy, the brightness will be a little on the high side when the supply is too high. Voltage regulation faults can be from warn components in the voltage regulator area, or in the feedback control.
This should be looked after by an experienced TV service tech. This type of fault can be involved.
Jerry G.
Posted on Apr 28, 2008
Where is the reset button?
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... how do i reset my sanyo flat screen television?
Dec 26, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV ... video tutorial television flat-screen model # kdl ln lt lnt hp ht LINK for TV boards & Parts ... 1. soft reset - is just turning tv off & back on ..... the source by using the on/off button on the side panel, remote does not work.
Dec 29, 2015 | Sanyo Televison & Video
Model: CM21AF8A
the picture is produced by the following,
check the power supply, making sure that a high voltage is produced of about 90-110 volts, which later triggers a line transformer to oscilate.
a power supply is suppose to be checked expecialy semi conductors and diodes, also fusible resistors be checked make sure that the switch is okay power is passing through it.
Apr 12, 2009 | Sanyo DS32224 TV
Component code
codes-0154,0159 this is for the tv
Mar 09, 2009 | Sanyo DS32224 TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
TV in permanent zoom
The left and right arrows on the RCA remote control are the picture format buttons.....
Apr 12, 2008 | RCA P61939 61" Rear Projection Television
Sanyo DS32224 TV blurry
Do you have the original remote for that TV set? If you do not, you will need to get one or borrow an original Sanyo remote so you can get into the set's menu and go to puicture set up and try adjusting the constrast up a little bit.
Mar 20, 2008 | Televison & Video
32" TV Screen Problem
This is a pin cushoning fault. The failure is in the pin amp, and also most likely in the scan amplifier sections. The scan amps and pin amp in part of their functions work together to control the paralax of the picture scanning. They also control the dynamic focus.
To service this, you will need the training, service information, the testing tools, parts availability, and the necessary tools to follow up.
These types of faults can be complex to service, and can be a chalenge to even an experienced tech.
Jerry G.
Jan 04, 2008 | Sanyo DS32224 TV
Sanyo DS32224 TV Logo
425 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
