Question about Hotpoint RGB745 Gas Kitchen Range
I have a HOppoint RGB745 gas he gas supply piperange on order. I am building a new house and need toknow the correct dameter of the propane gas supply pipe.
  • floetterle Jul 01, 2009
    I do not know the diameter of the inlet pipe on the range itself. Does this matter with regard to the diameter of the supply pipe from the tank to the range?
    The FixYa User guide for this range tells me nothing but basic dimensions; no info on gas piping sizes.
  • 50 Answers
1.5' to 2.0'
Posted on Jul 01, 2009
    President:
  • 1,383 Answers
  • 374 Answers
Here's the link http://www.engineeringtoolbox.com/propane-gas-pipe-sizing-d_830.html You have some related link at the bottom...and here are some questions and answers link http://du-lite.com/instructions/pdf/OI-Gas-Burner-Instructions.pdf ...It can be of some help. You have to keep a lot of things in mind before you choose the correct size...you can even consult the gas supplier for the size.
Hotpoint propane model rgb746hed2wh oven burner will not turn off, Digital reading f-2
F2
During BAKE, Control senses oven temperature above 615F-630F
f actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). Here is the part to order.
Dec 16, 2013 | Hotpoint RGB745 Gas Kitchen Range
I installed Goodman equipment in my new house, but i will be using propane for heat and the furnace gas valve is for natural gas. I have heard that there is retrofit kit to conver the valves to propane.
there should be a supply house or a supply store that deals only with heating and air conditioning they should be able to help you . but i believe you need your epa license
Aug 11, 2010 | Goodman CKL60AR60 Air Conditioner
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
What is the cause of carbon Build up? does it happen due to improper mix of oxygen? How can you cut down Carbon build up in fast pace professional kitchen resort?
Yes, You are correct on the carbon build up being incorrect air gas mixture. I would suspect a yellow flame rather than a blue flame. You may want to lift the top up and look at the place where the burner mates with the manifold. You may find grease build up, blocking off the correct air mixture. The burners usually can be lifted out to assist in the cleaning of the air intake.
Apr 10, 2010 | Hotpoint RGB745 Gas Kitchen Range
Belling farmhouse 911
Propane I take it.?Order from a parts house the "propane conversion kit".It should have orifices (2-3) and a spring .You Have to replace the parts to allow the propane to work. Please Rate This !!
Jun 07, 2008 | Belling FarmHouse 931 Gas Kitchen Range
Fumes
are you using propane or natural gas you may need to change the setting for what one your using in the back it will have a bag filled with new orifices you may need to change them out plus on the regalator you can switch to natural / propane
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
49 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
