Question about Stanley Staple/Nail Gun Elec
The spring has come out and we don't know where to put it
There isn't any pressure on the handle, The spring has come out and we don't know where to put it!
if u cud tell us ASAP it wud b a great help!!!
thnx in advance
    Sergeant:
  • 384 Answers
The Spring keep the Staples against the Stapler driving tool. Normally there is a metal pad to push against the staples, a rod that goes thru the Spring with a metal latch that locks inside the Stapler.
Posted on Jul 01, 2009
Why do my steamer steam without the trigger engaged
Check owner's manual. Is this the first time you used it? If so the trigger valve allows a small amount to "vent" so there is no excess pressure as a safety device. Similar to a pressure cooker.
Mar 05, 2015 | Scunci 52067 Handheld Steam Vacuum
Pressure washer only works if you crank it with pressure handle open , then works great if you let off it builds up pressure . and no water will come out when handle held fully open , bleed off pressure...
Hello..the unloader valve on the pump where you attach your water supply and your pressure outlet hose is the problem.There is a spring relief valve that is most likely frozen and not allowing the water pressure from the pump to circulate within itself.They range from 60.00 to 150.00 depending on your make and model.
Aug 19, 2011 | Briggs & Stratton Pressure Washer...
It won't spray water!!
I have a model Bissell Proheat Platinum II Model 1699 that was not spraying. It looks to be very similar to your model. From reading other posts, this is what I did:
Frst make sure it isn't the pump. Try spraying with your accessory. The accessory does not use the heater. If you get spray with your accessory, your pump is okay. If you don't get spray, check the belt to the pump. If it isn't the belt, you may need a new pump.
Luckily, I got spray with my accessory, so now you need to check your tubing from and to your heater. As stated in other posts, the heater is located within the lower half of the handle where the POWER HEATER switches are. There are quite a few screws. It's easy to miss the one at the very top of the handle. First remove the accessory caddy and then remove one half of the upper handle. The other half of the upper handle lifts straight up allowing you to split the lower part fo the handle into a "V". It pivots at the bottom around the wheels. It took me a while to figure out that I needed to LIFT that part of the handle straight up.
Once you split the lower half, you will see the heater (aluminum box). There are two ports on the heater where the two lines connect to the heater (in and out). Use pliers to loosen the spring clip where the tubing connects to the heater to remove each line. My lines were okay. One of the ports on my heater was plugged. I used a 1/16" drill bit and hand reamed out the crud. You don't need to use a drill -- use your hand - it's safer. After you cleaned out the ports and your tubing (if needed), suggest you try it out after reconnecting the lines to the heater but before you put the handle back together. You may find that the lines or port needs more cleaning. Make sure you have water in both the water and cleaning solution vessels. As you know, no water will spray if EITHER one is dry. Turn it on and then press the little spring that's still in the handle. Hopefully you will get a water spray.
When you put the handle back together, be careful that you don't crimp the tubing. Tuck them back in the notches in the handle.
Hope this helps . Good luck.
Feb 20, 2011 | Bissell 1698 PowerSteamer ProHeat Upright...
SuperBox USB
Go into factory default to delete files ,then auto scan the channels and remember to go into EMU and switch to on position
Mar 07, 2010 | StarTech.com StarView SV211K 2-port KVM...
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Lost instructions for es20 safe
This document might be of help - you'll have to determine which is your proper setup.
http://www.sentrysafe.com/pdfs/OwnersManuals/IntBarracudal.pdf
Feb 22, 2009 | Sentry Fireproof Safe
Liquid problem for camera
there's no other way,how your problem could be solve but to replace your camera...
Mar 27, 2008 | Sony Ericsson W700i Cellular Phone
I put in a DVD and it says NO DISC.
1st, I think the term 'Expert' is used too loosely here, at least for me. LOL. I just had the pleasure of fixing an IDM-1731 with a 'No Disc' error. It just so happens that calibrating the drive helped me out.
For any of you that feel like taking a risk & opening up your player, I urge caution when handling the optical lens. There are 2 pots located above the ribbon on the end that connects to the lens to the left. The 1 on left I touched to the right & that helped me out. I'm thinking that the vibration caused the player to get out of whack as time goes on.
After getting the player to work, I took measurements with my multimeter. The left pot measures 3.06 k ohms & the right measures .965 k ohms. I hope this helps others out as it did for me.
Nov 23, 2006 | Initial IDM-1731 Portable DVD Player with...
Stanley Staple/Nail Gun Elec Logo
349 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
JOHN LAPIER
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
