Question about Lexmark Office Equipment & Supplies
I am not sure if my printer is online because when i click print on my computer nothing happens
Check for any lights on the unit and also listen to see if the fans start up when you power the unit up. Most printers have a self test button see if you can print the internal self test. What kind of printer do you have?
Posted on Jul 01, 2009
Local print spooler not working. What do I do?
Try to uninstall the Lexmark driver and download an updated driver online. Just go to http://bit.ly/UmL4pl and choose the operating system of your computer.
If it doesn't help, check your print spooler if it's running. To do that, on your computer, click on Start > Run > type in Services.msc > OK > look for Print Spooler and make sure that it's started.
Nov 13, 2012 | Lexmark X4550 AllInOne InkJet Printer
Does not print from my computer
Try to do a test print using the printer utility installed on your computer and also check if the driver is properly installed on your computer and if not make sure that your printer is using the printer driver from your setup CD.
Hope that helps...........
Jul 17, 2008 | Lexmark Z640 InkJet Printer
Printer is offline
Hi, turn it's power on. be sure the usb/data cable is connected to the cpu, if still not, remove the printer's adapter and connect it again, power it up again. if not still online, restart your pc.
When you want to print a document, you choose print and select your favorite printer but nothing happens. You look at the printer menu and see the pesky printer offline message and instant frustration. The task of the moment is going from offline to online. With creativity and patience, you'll have your printer back online in no time.
Instructions
Attempt to set the printer to online. This may not often work but it's the first action to take. Go to "Settings" and then "Printers". Right click on the "Printer" and select "Use Printer Online". Test the printer to see if it now prints.
Clear any print jobs. Double click on the "Printer" after performing the above step. Go to the "Printer Menu" and select "Cancel All Documents". There could have been a stuck print job that would cause the printer to go offline. Try once again to set the printer back online and try printing a test page.
Turn on the printer. Make sure the printer is turned on and turn it off, wait a minute and then turn it on again. Check to see if the is jammed. Check all the network connections to make sure none are loose. Repeat the above steps again if necessary.
Restart the computer. If this doesn't work, you will have to reinstall the drivers. Go to "Settings" then "Printers" and select the printer. Right click on the printer and choose "Properties". Under the "General" or "Details Tab" look for the driver button and select it and choose the driver again. You may also have to download the driver from the printer manufacturer website.
Reinstall the printer. Under "Printers" in the "Settings" menu, go back and select the printer, then delete the printer and reinstall the printer through the add printer wizard. Use the latest printer driver from the printer manufacturer's website.
Hope it helps.
Thanks for using fixya.......
Dec 06, 2010 | Epson Stylus NX100 InkJet Printer
My printer will not print jobs from computer , it will make copies and it will fax but when I click on the icon to print nothing happens. I just put a new ink cartage in. I tried the test page and it...
Right click on the printer icon in the Printer and Faxes menu. Make sure in the pop up box it says USE PRINTER OFFLINE. If it says USE PRINTER ONLINE, click on it and then try printing again. You may also want to double click on the printer icon and make sure there is nothing scheduled for printing. If there is, cancel it and try printing again. If that doesn't work, make sure you have the correct driver selected and it is connected to the right port.
Oct 08, 2009 | Brother Multi-Function Center MFC-240C...
My computer states my printer is ready,but when i press print nothing happens
make sure this printer is your default printer. check in printers if the printer is online, make a test print. remove the cable and insert it again. try reinstall the driver again
Aug 09, 2009 | HP Deskjet 840 InkJet Printer
Printer not printing
check to make sure cables are securly fastened and if it's a laser printer make sure it is set to online mode and not offline mode. Check to make sure not out of toner or ink. Make sure no other print jobs are in the way, Reset the printer. Try a printer self test and make sure the settings on the printer and computer are both set to the same. If none of this works you might have a hardware problem that needs to be fixed. if you have a warranty on the printer call the warranty company as they will fix the problem for you.
Mar 02, 2009 | HP Officejet 6310 All-In-One InkJet...
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
HP Photosmart C4380 All-in-One printer
check the ports first.. make sure that the printer is set as default ( make sure it has the green tick and the status "ready" or "online" on the printer icon in the printers&faxes. and if u want to connect it wirelessly, you have to install it as usb first before changing to wireless........
Jun 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
No printing...?
Make sure after you click 'print' that the printer you are printing from is not the 'fax'. I had this happen too... just a suggestion ;)
Apr 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printer won't print online
i suggest to uninstall the driver of your printer then restart your computer, then install your printer driver again. just follow the printer installation procedure. thanks!
Apr 02, 2008 | Microsoft Windows Vista Ultimate Edition
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
