Question about Dryers
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
  • Dryers Master
  • 744 Answers
Hello Sandy;
My name is peter. I am a retired field service appliance technician.
You did not provide a model number, which is located on the face of the dryer after you open the door. So, I can only be general.
A dryer if cleaned annually should last you 20 years plus.
- Some Heat -
1.) Poor Air Flow - If you are getting heat but your have to cycle several times then you have a hot air distribution manifold that is plugged up with lint.
- No Heat -
I would be surprised if you have a bad electric heating element, since your dryer is only 3 years old. Heating elements can cost $37.00-$67.00.
1.) Thermal Fuse - This component is designed to protect your dryer and is a weak link. It cost about $25.00 and is easily replaced depending on your model number and where it is located.
2.) Temperature Sensor - This component also is about $25.00 and once again depending on location is easily replaced.
Send me you model number and advise if you know anyone that knows what a screw drive is.
If I were still working for Sears Home Services and made this service call, I would be charging you $350.00-$450.00 depending on the problem.
If you can not do the repair yourself - You unit is under 5 years old. So, you can get a Sears Home Service, "Protection Agreement". Have the model number, serial number, and date of manufacture ready. This is on the label described above. If you have the date of purchase that is great.
Call Sears Service. Ask for a "SMART" agreement. This covers you for $500.00 per service call. If you have to call 3 times in one year, each service call is covered for $500.00. If your unit can not be fixed then they give you a $500.00 credit towards a new unit.
This contract will cost you about $90.00.
Wait about 3 weeks. Then call and say your unit is not heating and schedule a service call. The technician does not care when you got your agreement. He is there just to repair your unit and move on to his next 10-13 service calls.
Make sure you do not let them talk you into the, "Master Protection Agreement." It is very expensive covers replacement of your unit if it can not be repair. You do not need that. Insist on the "SMART" agreement.
Posted on Mar 22, 2015
  • 845 Answers
If its not heating up, then you may have bad heating elements.
Posted on Mar 21, 2015
    President:
  • 1,723 Answers
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Samsung front load dryer will turn on but not spinning or drying. I was wiping it out and turning the drum I heard a snap sound.
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Jan 10, 2011 | Samsung Dryers
Heard a thumping noise everytime we turned dryer on...lasted a week or so.....drying a blanket last night cycle stopped half way thru.....still getting hot, just not turning. Thinking this is some type of...
The thumping noise comes when the drum is rubbing against the body surface. This could be due to the suspenders/support which is holding the drier drum are not steadfast. May be one has given the way. To know exactly if it is the belt or the coupling with motor or the support for drum , you have to open the back cover which you can do it by removing the screws at the back and then inspecting the machine.
Nov 02, 2010 | Frigidaire Electric Dryer
Heat and fan are on, but no action with drum
In my expierence with dryers you usually have to take the back pannel off not that one.
Oct 06, 2009 | Kenmore Elite HE4 Electric Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer only hums when I turn the knob.
Something has seized the motor. It could be something in the blower(pen pencil, golf tee, you'd be surprised what can get in there). It could also be a seized bearing on the motor. There are electrical things that could have those symptoms but I would check the mechanical ones first. Let me know what you find.
Eric
Jun 10, 2009 | Dryers
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Indesit condensair dryer
I have had a similar problem, my wife tried drying clothes that were too wet, causing the machine to flood. Even though she emptied the tank, the empty water light was always on!!
What I did was take the electrical plug out and tip the machine to one side, you probably will find there will be a collection of water in the base, which will leak out. Once you think you emptied it, plug it back it back in and try it.
It worked for me!
Stooooman
Aug 15, 2008 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
