Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
Typewriter was working fine, hit margin release and line space lights started flashing and keyboard became nonresponsive. The carriage will move manually, but can't get those flashing lights to go away!
  • lori_r_laub Jul 03, 2009
    Thanks for the response! I have tried your suggestions and no luck thus far. It beeps once when I turn it on and then the 1, 1.5, and 2 line space lights blink continuously. When I manually move the carriage and turn the typewriter off and back on, the carriage will move on its own back to the starting position.
  • IBM Master
  • 3,594 Answers
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Posted on Jul 02, 2009
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
How do I re-program my typewriter? the margins are too far in. IBM Wheelwriter 15 Series II
Go to the margin, press margin release, space or backspace to the desired location, press L. or R. margin.
DickyO
Dec 10, 2010 | IBM Office Equipment & Supplies
IBM Wheelwriter #5 - The line space keys are flashing and the typewriter will not work. I unplugged it and replaced the batteries.
There are a lot of possibilities. Which lights are flashing? In sequence? Beeps? How many?
These all are codes to the problem.
DickyO
Sep 15, 2010 | Lexmark Wheelwriter 5 Series II Typewriter
I need to reset the margins of my AT&T typewriter
L. margin - return to the margin, press and release margin release key, space or backspace to desired location, press L. margin key.
R. margin - space to desired location, press R. mar key.
you can download a manual at Lexmark.com click your way to publications.
DickyO
Feb 08, 2010 | IBM Wheelwriter 30 Typewriter
Beeping IBM personal wheelwriter
It could be that the right hand margin is set very close to the left margin. Try spacing way over to the right side of the typewriter and resetting the right margin there.
Mar 09, 2009 | Office Equipment & Supplies
IBM wheelwriter 15 Series II not working
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
Dec 30, 2008 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 5
You probably have the right margin set to close yo the lrft and have auto return on. To turn off auto ret. hold the code key and touch "R". To move the margin tab to the rt. side and touch rt. mar. key.
DickyO
Jun 30, 2008 | IBM Wheelwriter 30 Typewriter
MARGINS
Move carrier to left margin press margin release, top left hand side of keyboard, back space to desired position and press L Margin key.  Margins will reset to default if batteries are dead.   Right margin simply space to whever you want the margin and press R Margin.
Oct 24, 2007 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
745 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
