Replacing motor coupling
Wow to replace motor coupling
    President:
  • 1,136 Answers
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
  • Victor
    Victor Jul 01, 2009
    Vic
    Sergeant:
  • 353 Answers
IF WATER IN TUB:
unplug power.
remove 2 screws at the bottom of the control panel.
flip panal backwards over.
unplug wire connector through top of machine.
remove 2 spring locks with strong screwdriver.
tilt body forward 45 degrees and lift off.
release 2 spring clips motor to trans.
pull apart assembly.
remove and relpace entire coupler
reassemble in reverse.
IF NO WATER IN TUB:
tilt or lay machine on it's side.
refer to last 4 steps of "if water in tub"
my wife did this 3 time by her self then bought a front loader
My husqvarna 150 blower bogs down and shuts down when I accelerate.I replaced the spark plug,changed the fuel and filter.Any ideas?
How is the air cleaner? I just cleaned a couple in chainsaws and wow were they dirty. Ideally replace them but I cleaned cleaning in gas with a bit of oil and replacing. They are usually a small piece if foam about 1CM thick.
Mar 11, 2018 | Husqvarna Garden
How do I replace the motor coupling
Washer Motor Coupling (part #285753A) - How To Replace ...
? 8:35
https://www.youtube.com/watch?v=MYB5x-IqtIM
Aug 4, 2011 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace the drivemotor coupling on top load direct drive ...
Motor coupler replacing Whirlpool direct drive washer ...
? 5:08
https://www.youtube.com/watch?v=H0o95LEjBtM
May 22, 2011 - Uploaded by theapplianceman
For more videos visit my website at http://goo.gl/WdE9
Nov 23, 2015 | Washing Machines
MOTOR WONT COME ON AUTOMATICLY. I HAVE TO SPIN THE MOTOR WITH MY HAND THEN IT COMES ON
that is because the capacitor for the motor is bad...
The capacitor is the round or oval thing that is hooked by couple of wires to the motor and gives it the electrical kick to get it started...
Replace the cap with one of the same MFD an voltage rating...
heatman101
Feb 03, 2011 | Heating & Cooling
My head lamps make a noise every time they close...
I would try the oil or some silicone spray, the motor must be struggling to close. It looks just like a window operator motor. And they go bad, so, might be time to get a couple new ones, ebay, $16.50 to $415.00, Wow! I'd go to the junk yard. Hope this helps.
May 01, 2010 | 1999 Pontiac Firebird
I am trying to determine if it is worth fixing the timing chain on the 2000 oldsmobile intrigue. i hear they are fairly expensive. we just replaced a cracked radiator and the serpentine belt. The mechanic...
Wow. Only worth it if the mechanic is trustworthy and you can't afford to get out from under it. It is a pretty complicated repair. The car probably isn't worth more than a couple thousand dollars, depending on where you are located. Why do they want to replace the timing chain? How many miles are on the engine?
Feb 26, 2010 | 2000 Oldsmobile Intrigue
Driver side power window don't word
Replace the window motor...chances are it is burnt out.
Aug 21, 2009 | 2006 Dodge Grand Caravan
Replace coupler on kenmore top loader would like diagram
Go to searspartsdirect.com. You will have to put in the model number to do a search. The search will produce an exploded view along with the parts list and prices. If you're wanting to replace the coupling; the easiest approach is to lay the washer face down. Remove the motor mounts and replace the coupling. The couplings are plastic and fit tightly to both shafts. Pry coupling loose from motor and washer with a screwdriver. Install one of the coupling halves on each shaft. Sit the rubber center section on to the motor half of the coupling and install motor and motor mounts.
May 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
