Question about Canon IMAGERUNNER 2230 Copier
Canon 2230 my copies appear about an 1/8" skewed. is this normal and within the specs?
I have a cannon Imagerunner 2230 and it is not printing correctly. Labels are slightly off center and ink is fading off of paper and or lighter and darker letters and smudging.
Posted on Jun 29, 2010
  • 62 Answers
Try adjusting the document feeder by undoing the nut on the right hinge and slackening the screws. Trial and error could produce better results to within 1 millimeter.
Posted on Nov 09, 2007
Replaced toner cartridge in our cannon imagerunner 2230, but it still flashes error and will not reset back to copy mode. thanks
What is the error code that is Flashing??? That will till us what is wrong.... They range from E000 to E900, you guess is as good as mine
Mar 12, 2010 | Canon IMAGERUNNER 2230 Copier
Copies are gray, not black and fuzzy too
Try to set the darkest posiblle in user display and check the copie. If its ok you must try to clean benith the copy glass and scaner sensors. If didnt help try to replace the drum, and if not better clean laser unit.
How many copies do you have?
By the book the drum life is 75000 but it goes up to 100000 copies.
If your copies have "unbaked" toner all over it, you need to change fixing film unit.
good luck
Jan 27, 2010 | Canon IMAGERUNNER 2230 Copier
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER? HAVE CHANGED REGISTRATION ROLLERS, SKEW IS SAME FROM ALL TRAYS & BYPASS. TRIED ADJUSTING THE FOCAL LENGTH ON THE MIRRORS, AND STILL HAS ABOUT 1/8 INCH...
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
Image runner 2230- computer not recognizing IP adress for scanner
you must be shore that the cable between the copier and the co mputer is cross cabel and connected if there is a switch put normal cable
and then be shore that the diference between the two ip.s is smal as the computer ip 192.168.1.20
and the copier ip 192.168.1.30
Apr 28, 2009 | Canon IMAGERUNNER 2230 Copier
Analog copier skewness in copies
1-it could come from the ADF - if makingfrom the doc feeder adjust screws in rear or ADF
2-the scanner adjust the scanner - turn off machine remove glass and adjust
3-if making from feeder the glass itself may be too dry, spray WD40 and wipe leaving a smooth surface.
Sep 12, 2008 | Office Equipment & Supplies
153 people viewed this question
old marine
old marine
