Question about Microsoft MS Xbox 360 Common Controller (DHC8G00004)
Constant vibration on xbox 360 controllers
When you put the back part that holds the batteries on to the controller it just starts to vibrate constantly and doesnt stop the controller still works but it doesnt stop vibrating. and it is not the batteries because i have tried it out with several different batteries and it still vibrated. if you have any solutions i would really appreciate it.
2 Suggested Answers
Roswell453
  • 59 Answers
SOURCE: Xbox 360 controller keeps losing connection when vibration happen
first do you have a "short" in the Controller, try another one and see if it does, also try cleaning the game disk with something like "windex", also try "checking any add on memory, you could have a "Glitch", in either of these, but try them one by one, start with the easy ones first, let me know if I can be of more help, also try disabling the the "vibration", and see if it still does it, god bless and happy 4th
Posted on Jul 05, 2009
Xbox 360 Controller will not vibrate
so tell the ppl that u don't like what what the CONTROLLERS and u want new ones ARE U GOING TO SEE THEM IN PERSON
Jul 24, 2013 | Microsoft Xbox 360 Wireless Controller
Tip
Get wireless Xbox 360 controllers to stop disconnecting
By disabling the vibration on the controller, you can keep the batteries in place and the controllers will disconnect less often. If you want to keep the vibration feature on, then use some tape to secure the batteries in place before you put the cover on.
on May 15, 2011 | Video Game Consoles & Games
Controllers keep disconnecting on modern warfare 3
This is due to loose battery packs on the controllers and the pad vibrating shaking them loose. Try some duct tape to hold them in place, or purchase some rechargable battery packs.
Oct 18, 2012 | Activision Call Of Duty Modern Warfare 3...
My xbox 360 vibration wont work on black ops. :( It works on every other game but not black ops please help!
Im pretty sure you can change that in settings..when youre in game, select start/options and towards the bottom you can select vibrate.
May 14, 2011 | Microsoft Xbox 360 Controller
My xbox 360 controller keeps turning off when i shoot or do anything in halo reach and the batteries are brand new.
It means that the controller battery holder is loose and the batteries are loosing contacts with the terminals, this happen specially when the controller vibrates. Try to put a piece of paper or plastic in the inside covering the body of the battery or a tape to thicken it a little then place the battery in the battery pack holder and it should work fine. Hope it helps.
May 10, 2011 | Microsoft Xbox 360 Controller
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Wireless xbox 360 controller keeps disconnecting when i fire or get shot evertime whats the problem
I've had this same problem with a few controllers. It's your battery. Well, more specifically the container of the batteries. Chances are, it's lose.
(I would have to keep holding mine firmly in place, while playing games.) The reason it disconnects when you get shot is cause of the controller vibrations. It makes your battery jump out of place, due to not being held in place firmly.
My suggestion would be to either buy a new battery container, or turn vibrations off.
Hope this helps.
Feb 02, 2010 | Microsoft Xbox 360 Controller
My xbox 360 controller just started freaking out in the middle of playing today. Everytime I fire my gun (causing the vibration) my character will start looking down and then my controller shuts off. I...
Turn the vibration off in the options menu of a game that allows it, if the game play is fine then you may have to ask Santa for a new controller, as that one sounds like it is starting to fail.
Aug 23, 2009 | Microsoft Xbox 360 Controller
Xbox 360 controller turns off at random, yet has new batteries
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries(or more specifically - bad batteries) - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. I'd recommend a recharge while you play pack. ALWAYS by the official products too. They're much more reliable and aren't prone to this kind of behaviour.
Jun 26, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless control conects then disconnects randomly
The solution is VERY simple.
There is nothing wrong with your controller OR your xbox.
The problem IS low batteries - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
Thumbs this up when it proves correct for you. People will find the solution quicker that way.
May 04, 2008 | Microsoft Xbox 360 Controller
Microsoft MS Xbox 360 Common Controller (DHC8G00004) Logo
1,564 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
