Have dye around outer seam of compressor, is there
Have dye around outer seam of the a/c compressor, in my 1990 GMC truck, is there a internal seal in this location?
  • 2,418 Answers
Not sure which seam you are talking about. But here goes, the compressor will have a front plate that will have a seal at the shaft behind the clutch, then a gasket (or o-ring) to seal that plate to the compressor body. Then at the other end where the hoses are, you will also have a gasket (or o-ring) in between the body and this plate. You will have a plate or an adapter that bolts to the end plate that the hoses bolt to. any one of these gaskets (or o-rings) can leak. If it is in the front area close to the belt or clutch area that could be the shaft seal, that is the only part I would tell you to try an replace, the body gaskets are too risky.
Posted on Jul 02, 2009
Is repair time and parts extensive for this type of repair? Kenmore Front Load Model# 110.45986401
Confirm that it is not the door seal. The door seal can easily be replaced and the parts are available.
You would expect that any water leaking around the door seal would migrate down to the lowest part of the tub leaving the appearance that the leak is where the two half's of the tub are joined by the retaining clips
Replacing the seal between the two tub half's is a different story as compared to the door seal. The tub seal is definitely do-able, but not for the faint of heart!!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
If the leak is very very small I might wait until a major overall is require such as the tub seal/bearing. If I chose to wait I would monitor the situation.
Inspect the area at the hub of the pulley looking for streaks of rust.. If there is an indication that water is leaking past the basket tub seal than doing an over hall now may included front door seal, tub seal, bearing and basket seal replacement.
Dec 30, 2015 | Washing Machines
A/c is leaking dye put in but having a hard time locating leak looking from top of engine?
Start by looking for dye at the hose connections. Then move to the ports where you connect the charging hoses. Follow the hoses and metal lines up front to the condenser which is in front of the radiator. If you dont see any dye yet then take a rag and wipe off the clutch on the compressor. If dye is on the rag then you've found that the shaft seal on the compressor is the source of the leak. This location is the most likely place to leak with the valves on the charging ports coming in second.
Apr 30, 2014 | 1997 Buick LeSabre
Yukon a/c blows hot air
Assuming you hear some kind of clicking noise when you turn the AC on (the compressor clicking on):
Seals on the AC compressor likely bit the dust. GM AC compressors go out almost as frequently as tires. The good thing is that they're not horrifically difficult to replace. You can get some freon with dye in it at your local parts house. Get enough to fill it up as though it's empty (as it likely is), and see if it starts blowing cold. It should blow cold for a little while (days/weeks maybe), but when you open the hood, you'll notice some green dye around the compressor. That's where the seals have failed and why you get to be the proud new owner of a brand new compressor (don't waste your time on a used one from a salvage yard. You'll get to replace it again soon, if you do.)
Sep 02, 2012 | 2003 GMC Yukon XL
Cant find refrigerent leak on 04 trailblazer
Mechanics use dye or a device that "sniffs" for leaks since the gas is hard to see.
Putting in fluorescent dye allows you to see the dye with a black light.
The sniffer picks up a component of the gas.
If the system was charged before you replaced the compressor, the leak should be at one of the gaskets you replaced, or you have a defective compressor which is leaking at the pulley seal.
Jul 01, 2012 | Chevrolet TrailBlazer Cars & Trucks
Husqvarna 141 oil leak
This model was notorious for leaking oil, there were a number of issues, one of which was the fit of the seals around the oil pump assembly, the inner and outer sealing was replaced by a single piece seal to make it better part no. 545037101, there were also issues with the oil tank itself, the outer half was friction welded on to the inner, some of the seams were not very good and oil would leak from there, in very extreme cases the muffler would leak exhaust gas onto the top of the tank and melt a hole in the tank.
Feb 26, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My a/c cabin cooling begins to degrad 4 to 5 days after a recharge. The dealer recharged with a UV leak detector after pressure checking but could not immediately detect a leak anywhere. They said to bring...
To find the leak ,if it is the evaporator,look ,for the dye to come out the drain where the condensation drains,Wash the excess dye of the service port with carburetor cleaner,it is most likely spill over.Inspect the compressor too,they are more likely to leak at the seams,and the shaft seal.Look under the compressor,it will drain down,do not forget the condenser,look at it on both sides.I hope this was helpful
Apr 11, 2010 | 1999 Jeep Grand Cherokee
Will not keep refridgerant for more than a month and I have replaced the (fuse) twice. Can the compressor have an internal leak?
rarely does the compressor leak on these sealed units,have someone certified put in some leak tracer dye into the freon/refrigerant system and when or where it leaks out there will be a florescent leak spot you can find with a black light tube light anywhere in the sealed system
Mar 23, 2010 | Kenmore 53592 / 53594 Side by Side...
On my 2004 xterra, the compressor operates, but a/c blows hot air. i have charged it and that lasted 1 day. now hot air again.
The engine drive belt operates the AC compressor. The OUTER pulley on the compressor , where the belt is, is always turning when the engine is running. When the AC is turned on, a CLUTCH on the compressor is engaged and connects the outer pulley to the compressor shaft. So, when the compressor is actually working, the outer pulley AND the inner ring just behind the outer pulley are both turning. When the AC is off (or not working correctly, as in your case), only the outer pulley turns.
It sounds like there is a major leak somewhere in the system. If you want to try and to find the leak yourself, there is a product in auto parts stores that is made for this. It is a canister, like the refrigerant used to charge the system, that will blow out a dye in the system, where the leak is. This can help you identify where the leak is ....If this info was helpful, please post... Thanks...
Jun 27, 2009 | 2004 Nissan XTerra
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
