Question about GE Refrigerators
Water collecting on the bottom of my GE monogram refrigerator.
I have a 10 year old GE monogram built in refrigerator. I am finding water collecting on the floor of the refrigerator which seems to be coming from the vent between the freezer and the fridge. I had the timer replaced on the heater for defrosting about a month ago. There is not water outside the fridge. I do not have an in-door ice dispenser/water dispenser. Can you give me any ideas about what is wrong?
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. back.
Posted on Dec 22, 2006
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
  • 10 Answers
SOURCE: smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Posted on Mar 12, 2009
  • 44 Answers
SOURCE: 10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Posted on Jun 10, 2009
  • 4070 Answers
SOURCE: How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 26, 2009
I have a GE monogram side by side refrigerator and water has started collecting in the "express chill" drawer at the bottom of the refrigerator side. It appears to be collecting in the "ceiling" of th
water into the fresh section or just on the floor around freezer or fresh food door. I also cannot take all credit for solutions in the area of refrigerators leaking water. Every person contributes their own experience so those that have should also be rewarded for their own efforts. I am pretty sure you are having a defrost by CouponDropDown">drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Mar 31, 2013 | GE Monogram Side by Side Refrigerator
Monogram profile GE smells; can't see where water might collect? is clean; opened the top coils were vacumed recently; ???
blow out drainpipe/vent or use fine wire with a small cloth tied to end dipped in clorine bleach gunk is streptococus, grows naturally.....
Feb 08, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
May 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE zir36n rh Monogram 36" built in refrigerator
I finally got my refrigerator fixed after three years of complaining. The units are set up to have the fan running even if the cooling unit is not currently on. So when the unit is not cooling, then the fan is brining in moisture from the outside air which causes the water/mold. GE repair rewired the fan to run only when the unit cools on 4/20/10 and it has fixed my problem!!! Of course, this was only after I have thrown out a LOT of food!
Oct 03, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
