Question about Timex Watches
Shorten watch band- Timex
Brand new Timex ladies' watch T2M161. the band is several links too long. I can't see how to remove any links (safely)
the links have a "direction," obviously; they go in one direction starting from one side of the watch and from the opposite direction starting from the other side of the watch, I'm afraid I'll mess it up if I start poking on things that "might move" but nothing is obvious like a pin that would come out, no arrows, etc.
thanks for any tips.
tony
  • Sweeps Feb 15, 2009
    How is the watch band of a Timex T2M161 adjusted?
    Sweeper
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
  • 183 Answers
SOURCE: shorten watch band
For this you will need a pair of fine tweezers, a small flat blade screw driver and a lot of patience.
Determine how many links you need to take out by pinching the band while it is on the wrist. Once you know how many you are ready to remove the links.
spread the band and you will see that the very end of the links is tabbed. Be careful and fold down the end of the link with your small screw driver. Be careful not to bend anything. You will then need to turn the band over and bend down the tab of the link on the opposite side but right beside the first tab you bent down. Now you will see how the band is held together. If you look into the two tabs you just bent down you will see a small peice of metal connecting the two links. This is a staple. Pull the staple out with your tweezers.
Now go to the exact opposite side and perform the same task. The band should now be apart where you remove the staples from each side.
Now count down the number of links you want to remove and perform the task again.
*Remember that you must do it the exact same way on each side or the band will not go back together.
Once you have the correct number of links out the band will go back together the same way you took it apart.
When folding down the tabs be sure to use gentle even pressure so you dont over bend them and keep the band from moving freely. I usually find it easiest to use the fla part of the screw driver in a gentle pressing motion.
Remember that this take watch makers and technician a lot of practice. Be patient. If you arent patient or good with very small parts, pop into your local jewlery store for help.
Posted on Sep 17, 2009
How to remove links from stainless steel link band from ladies timex cr 1215
you need a fine pin punch to do this and most shops that ct keys etc do this for small charge
May 08, 2016 | Timex Watches
Band too large . How do I shorten an expansion band that does not have pins? It is the Timex Easy Reader
You din't. Take it to a jeweler and have them do it for you. If you've never removed links for an expansion band you'll destroy it in the process.
Jun 08, 2011 | Timex T26451 Classic Expansion Band Watch...
Shorten watch band
Sep 17, 2009 | Timex 27191 Wristwatch
Help with removing links from a Calvin Klein ladies watch
There must be something wrong as ALL watch bands are held together by pins or screws. Did you try to unscrew them? These might be screws instead of pins. And if these are pins, they MUST come out because there is NO other way to shorten the band.
I would advise you to find the watchmaker, not the jeweller, and he/she will be able to sort things out.
P.S. Not all the bands has pointing arrows on them, so, no worries about that.
Do not forget to rate, please.
Jan 06, 2009 | Watches
Removing links to shorten watch for a ladies Wallmart watch brand is white stag #Ws50880w
I just removed links from one of the white stag watches today. The answer is in the link below.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Friction pins are used to hold the links together. I used a jeweler's screwdriver and a small hammer to tap them out in the direction of the arrow. I put them back in the same way.
Dec 28, 2008 | Pulsar Ladies Watch
Watches Logo
575 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
