Question about JBL Car Audio & Video
Tring to hook up a radio without a harrness
Which wires are which power,ground,remote,&speakers
Red,black,and blue
Posted on Jul 01, 2009
Will not turn on
Check to see if you have the right remote wire hooked up some radio have two blue wires one is blue and white the other is just blue. And for sure check the ground and make sure that the power wire has a good connection.
Nov 12, 2013 | Car Audio & Video
I have an AudioBahn A4004T Amp. It was working fine and then I had it sitting in my house for a few months. My cousin wants to use it in his car so he hooked the power cables up to his battery to see if it...
If you only hooked up the power and ground the amp will not turn on. You must also hook up the remote wire. This either can come from your radio, your fuses, or your power wire itself. If you hook it up to your radio then it will turn on when the radio is turned on. If your radio doesn't have a remote wire to amp then you can read your owners manual and hook it up to the radio fuse and when the radio turns on the amp will turn on. An lastly you can run a wore from your power wire to your remote plug in. But if you do this the nano will constantly be on if it is hooked up to the battery.
Dec 25, 2010 | AudioBahn A4004T Car Audio Amplifier
After market Radio not working in Chevy Aveo
there must be a fuse that you missed check under the hood and inside the car for fuse panels and make sure that connections are still hooked up the ones that your husband did.
Apr 03, 2010 | 2005 Chevrolet Aveo
Whats the color code for deh-780mp wiring harrness
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Sep 20, 2009 | Car Audio & Video
The lights blink 1 2 3 just as his....
hook up power to power and ground to ground, and remote wire to power amp or anttenea on radio
Jun 06, 2009 | Infinity 7540A Car Audio Amplifier
I have a deh p3900mp
Antenna does act as ground, just not the best way to do it. Use the 6mm bolt hole in the rear of the chassis for a mounting strap, run a wire from there to the factory (vehicle) radio harness ground.
May 17, 2009 | Pioneer DEH-P3900MP CD Player
I am tring to extend my mic distance from the radio without any luck can you help
Thats because the interface at the convertacom is different from that of the radio -- the convertacom supplies power to the mic on the mic audio lead while the radio uses a separate wire. Get the convertacom manual and see how the mic is wired.
Sep 30, 2008 | Audio Players & Recorders
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Nov 18, 2007 | Sony CDX-CA400 CD Player
Remote wire hook up
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
Aug 19, 2007 | Rockford Fosgate Punch 301S Car Audio...
Amp
Make sure the amplifier is turning on. Remember ther is three wires that power the amp Battery constant, Ground which in a fiberglass boat run ground to battery not motor, Plus make sure the remote wire is hooked to power, generally it is switched power. But if the amp is not turning on temporarily hook remote and power together to battery and see if the amplifier turs on. Second be sure you have a good set of RCA cables hooking the radio to the amp. And finally check and make sure the gain is turned up on the amplifier.
Aug 31, 2006 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Car Audio & Video Logo
146 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
