Does the foot pedal go up and down or is it stuck in one position? The foot pedal is quite expensive so I would recommend trying to have it repaired if possible. Otherwise, check eBay or other 3rd party vendors for a replacement. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us for them to determine if your foot pedal can be repaired.
SOURCE: Husqvarna Viking #1 use same foot pedal as the #1+ ???
Yes it will work, you can go ahead and purchase it.
SOURCE: Q foot for Designer 1 machine
Hold the foot in your left hand. Attempt to put the foot on, but when you begin to struggle bring the needle down through the foot using the hand wheel. Once the needle screw is lowered about 1/2 way, the ankle will easily fit onto the shank and you can put the screw in.
Bringing the needle down saves you from having to wrestle with the spring tension in the foot and take all the work out of it.
SOURCE: Husqvarna Designer 1 touch screen not working.
Take it back to the repairer to look out so you don't void any warantee.......phone first to arrange a convenient time to discuss.
SOURCE: Need Viking Husqvarna Designer 1 ESS Owner's Manual
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
SOURCE: where to buy foot pedal for Husqvarna 5610?
You need to find your nearest dealer. Go to Husqvarna Vikings web site and there is a dealer locator. Just put in your zip code and you find your closest dealer.
