Question about Qep Tile Cutter 19"
Broke a piece on the base where the bolt is. can i replace it?
    Sergeant:
  • 384 Answers
Is the break something that can be epoxied back together? If the pivot is broken I would just get a replacement unit. The base may be made from pot metal that can not be welded.
Posted on Jul 01, 2009
How do I replace gasket in toilet tank that leaks ? Thanks
the water closet is attached to base with a couple bolts that have rubber washers, take them out and remove the closet from the base, you will then see a rubber gasket that fits between the pieces. After replacing the gasket reassemble the pieces and be careful not to over tighten the two bolts that secure the top and bottom.
Jan 26, 2015 | Home
Tundra antenna removal
You will have to un-install the entire antenna system from the inside.
remove the panel carefully adjacent to the antenna system
undo the bolts and clamps that hold the system in place
you can try and install the new antenna piece without disconnecting the transfer wire that goes back to the radio. But usually you will need to get and install a new system.
just to keep you going in the mean time you could just use a old wire coat hanger "classic" just bend the hook straight and shove it in, you have your sounds back.
all the best
Feb 02, 2014 | 2010 Toyota Tundra CrewMax
Allen Bolt and attachments shot out of top hinge bracket when moving it across the room
Lois Wagoner (Female 58) That was a good year. I presume you still have the part you need, have you tried taking all of the parts to Home Depot, they're great help. Otherwise, get the tanning bed make and model and google parts for your tanning bed. I'm a 66 years "young" man and don't know it all, and when I need parts or cooking recipes I google and I'm a great handy person and cook
Nov 07, 2013 | Wolff Sunvision Pro 24S Tanning Bed
Bolt broke off in engine..
To replace the bolt you'll need to remove the broken bolt that is still in the head. To do this you need to drill a hole in the center of the bolt. And then you'll need to use a bolt extractor to screw the broken bolt out. than you can install a new bolt.
Jun 02, 2013 | Cars & Trucks
I have a jeep liberty05 and my oil pan drain plug was put in by last owner so tightly i had to use an irwin east out in doin so with my impact the inside threade piece that the plug screws into broke off...
YOU NEED TO BUY CORRECT SIZE NEW OIL DRAIN PLUG. YOU TO KNOW YOUR THREAD SIZE ON NEW OIL DRAIN BECAUSE YOU NEED THE RIGHT TAP AND DRILL BIT TO CENTER DRILL THE BROKE BOLT IN SIDE OIL PAN YOU NEED A CENTER PUNCH TO PUNCH A SMALL ENOUGH TO START THE DRILL BIT DEAD CENTER OF BROKE BOLT.OIL PAN NEED TO BE REMOVED TO DRILL HOLE STRAIGHT.THIS IN NOT A EASY JOB.EITHER YOU REPAIR OR DAMAGED OIL PAN DRAIN PLUG HOLE. YOU DRILL BIT HAS TO STRAIGHT WHILE DRILLING HOLE DEAD CENTER OF BROKEN BOLT YOU NEED TO MEASURE LENGHT OF OIL DRAIN PLUG BOLT. THEN USE A PIECE TAPE ON DRILL BIT WRAP A PIECE TAPE AROUND DRILL BIT THE DEPT YOU NEED TO DRILL THROUGH BOLT. LIKE I SAY THIS JOB TAKE SKILL AND A STRAIGHT HAND. BECAREFUL WITH DRILL AND WEAR SAFETY GOGGLES. DONT DO THIS FIX IF YOU NOT SURE OF MECHANIC SKILLS YOU WILL EITHER DAMAGE THE OIL PAN OR FIX THE PROBLEM.
Sep 19, 2011 | 2005 Jeep Liberty
Over time the hinge on my Dell 8100 Inspiron gradually froze up and broke the aluminum block in the middle of the the screw that held it in place, ie. half the threads on each side of the broken piece. ...
Very common break, best is to have service performed by some one that knows what they are doing, machine has to be taken apart and new base installed, sometimes if slight break they can be epoxy. but usually needs new base andor hinges.
Nov 04, 2017 | Dell Inspiron 8100 Notebook
I have a Di622 Nissin Flash, the base is broken. The part that slides into the hot-shoe. Would like a quote on the fix.
i have a Di622 Nissin Flash, the base (hotshoe contact piece that slides in camera) is broke is there anywhere I can order the replacement piece?
Jul 20, 2010 | Nissin Speedlite Di622 TTL Flash for Canon
Suction base broke off. Can I get replacement piece?
Mine did the same thing. I used JB Weld epoxy and made a new base. Just filled the hole where the base goes in and the stuck what was left in the wet epoxy. Let it set up and it is as good as new, maybe better
Mar 06, 2010 | Amcor 3900 GPS Receiver
The pin on the starting switch broke. Black and Decker CMM120
Same problem with ours. We used a bolt (cut to fit with dremmel tool) to replace the pin and the spring slipped over the bolt. I don't remember exactly where the two arms of the spring met the switch and handle, but it was obvious once the spring was on the bolt.
Aug 31, 2009 | Black & Decker 19" Electric Lawnhog...
Qep Tile Cutter 19" Logo
Top Qep Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Qep Measuring Tool and Sensor Expert? Answer questions, earn points and help others
