Question about Legacy LA1490 - American Series 2 - 1400 Watt High Performance 2 Channel Amplifier Car Audio Amplifier
AMP Issue When I plug the RCA wire from stereo to AMP, the light on the AMP goes from green to red and there no sound coming the speakers.
  • shazad Nov 18, 2007
    hi i have a legacey 11 la 1020 an the rca connectors hav snaped do u nw where i can get a set ? shazadh33@blueyonder.co.uk
  • mossman12 May 11, 2010
    how many speakers r connected to the amp ?
The problem would either be a faulty FET or a short circuit in the unit. if you know what your doing open the amp up and inspect it for any blackening on the circuit board or if any transisters, capacitors, diodes, etc looked charred. If so there are many places you can have this fixed at.
Posted on Feb 03, 2009
  • 15,935 Answers
Check for pinched wire causing ground loop. Screws and seats are easy culprits. If you have a spare RCA... or can borrow or buy a cheap one... run it from the radio to the amp without routing the wires in the car and test.
Possibly could be hitting metal behind radio. Be sure to secure and tape wires.
Posted on Dec 22, 2008
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V...
Senshin,
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
Oct 11, 2010 | Metra 705512 Ford Prm Snd Amp Plug Wiring...
Need color codes for 1995 ford explorer with premium sound system. Ive found my constant, ground, switched, and memory i need the color codes for the other harness
For 1995 Ford Explorer Car Stereo check this Wiring Diagram...
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Good luck.
Jul 07, 2010 | 1995 Ford Explorer
Red Power Protector light
Hi, the only way i can see the amp resets the stereo is that power is dropping. The amp should have its own wires directly to power/battery so as to not affect anything else.
On the protect, try to disconnet all the speakers, make sure the power is OK. If it appears to work, the there could be a problem with speakers/cables. Try a different speaker to see if it works. If the problem continues with speakers off, a different speaker etc, then there is a problem with the amp. Hope that helps
Jul 21, 2009 | Sony XM-2100GTX Car Audio Amplifier
Wiring a after market radio to an existing Ford.
This may help.... it's for a 2004 and I believe it should be close if not right on...
Car Radio Battery Constant 12v+ Wire: Red/White
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
May 24, 2009 | Pioneer Car Audio & Video
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
Similar prob.did the 12 steps on how to install amp(jensen4100,blue).red protec light comes on when starting car then goes out and is not followed up by the green protec light .green one never comes on....
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
May 16, 2009 | Jensen LXA300 Car Audio Amplifier
1994 FORD EXPLOER XLT RADIO CONNECTORS HAVE BEEN CUT OFF
here is wire color diagram.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Right Front Speaker Negative Wire (-): Pink/Light Green
Left Rear Speaker Positive Wire (+): Pink/Light Green
Mar 29, 2009 | 1994 Ford Explorer Limited
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Sep 29, 2008 | 1996 Ford Explorer
Legacy LA1490 - American Series 2 - 1400 Watt High Performance 2 Channel Amplifier Car Audio Amplifier Logo
62 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
