Question about Samsung HL-R5078W 50" HDTV
I have a samsung hlr5078wx and there is no picture and no sound. When the TV is powered on it sounds (makes the beeping sound) like the TV wanted to turn on but doesn't. There are no images and it seems to turn off and try to turn on again... Usually the third it this happens the 3 lights on the front button turn on which indicated that the bulb is bad. The bulb has been replaced 2 times and bith times they work for a day and then we turn it off for the night and doesn't turn on again the next day. Also the ballast underneath the bulb has been replaced. What could be causing this to happen? Thanks.
  • 76 Answers
Sounds like a major problem with the main motherboard (digitial board). Bad news and costly
Posted on Jul 16, 2009
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Samsung LNR 328W
Power supply failure
Nov 06, 2017 | Samsung Televison & Video
Samsung dlp tv no pictur no sound no beep
Inspect both the lamp and the color wheel that faces the lamp--unplugging simply makes the set try to reboot.
May 27, 2012 | Samsung HLT5675SX
Samsung hlr5078wx DLP tv. rumbling noise and shaky picture
This is a color wheel problem.
I would recommend to use professional help because you can make more damage to the optical engine. Not to mention index delay have to be re-adjusted in special service menu after repair is complete.
Regards.
Russ.
Jul 23, 2010 | Samsung HL-R5078W 50" HDTV
Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
value is 1000mf at 16volts usually replace four of them
Aug 20, 2009 | Samsung LN-T4665F 46 in. LCD Television
Replacement color wheel for samsung 50'
I am having the exact same issue with the exact same TV. They no longer make that color wheel, so I am looking for a replacement part as well.
I am looking at the 01103A as well from here:
http://www.partstore.com/Part/Samsung/Samsung/BP9601103A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLR5078W
I think I might just order it, and if it doesn't work just return it.
Jan 15, 2009 | Samsung Televison & Video
Beeping Sound
Maybe the horizontal IC output are damaged need to be replaced
Nov 04, 2008 | RCA F36650 36" TV
Failure to start, period.
the whining you hear is most likely the color wheel
it need to reach a curtain rpm before the lamp will kick on
i will almost gurentee one of the colors is broken on the wheel
Mar 12, 2008 | Samsung HL-R5078W 50" HDTV
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
No picture and beeping sound emitting from unit.
We have had ALOT of samsungs in the shop lately and the most resonable solution for these units is just to replace the controll box as a whole. goto www.vancebaldwin.com and login as guest and search for it by model #.
Sep 15, 2007 | Samsung SlimFit TX-S2783 TV
Samsung HL-R5078W 50" HDTV Logo
240 people viewed this question
Jerry Greenberg
Jerry Greenberg
