HP Hewlett Packard 2009m 20" Diagonal Lcd Screen Flat Panel Monitor Logo
A
Anonymous Posted on Aug 19, 2014
No sound sound level is up but nothing happens
Ivan Bernal
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 23, 2015
Ivan Bernal
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
5799
Points
17
Ck the link below and this could fix the issue
Go to the control panel and check device manger. Look for sound device and see if there is an X or ?. X means disabled. ? means driver issue.
Note: make sure your speakers are work or try to connect your head phone to the green female input in the back of the pc or look for a head phone symbol
HP 2009m internal speakers HP Support Forum
2answers
85 gmc s10 automatic transmission 4x4 when put in gear,nothing no two or four hi or lo, nothing
Check transmission fluid levels. You may have Shift linkage problems. Usually rubber bushings completely worn out. It could also be a similar bushing problem at the shift lever piviot.
2helpful
Heater only works on levels 3-5 . Levels 1&2 nothing happens
sounds like the blower motor resistor is bad. it's located on the passenger side under the dash behind the blower motor itself. Just changed mine on my 2004 sierra. Fairly easy job to do. Hope this helps :)
Black Screen Wii
Nintendo support or repairer would be your best hope, as it does sound like a low level brick.
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Whining noise in reverse
its a normal sound nothing to worry about every car does it that is front wheel drive
What is wrong with my audio plug?
Yep, you blew it up, all right.
The headphone jack in the laptop is a low-level OUTPUT which goes TO a set of headphones or the INPUT of an amplifier. You went the wrong way and fed a high-level signal (the guitar amplifier OUTPUT) INTO the laptop.
The electronics inside the laptop are not made to deal with the high level you fed in, so it's been damaged. Ever blow out a set of speakers with too high a volume? That's basically what has happened here.
To fix the problem and get your sound back would require a new system board.
I need listen rington when someone call me.
the problem might be you have kept ur mobile phone in silent mode or the ringtone sound level may be low.pls rate me
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
1helpful
Sound Problem
the amplifier must have an individual speaker volume controller that allows you to set different volume levels for each speaker independently, find it and set new levels.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
