Question about Dryers
Not heating suffiently. It just heats to slightly warm and not hot.
    President:
  • 1,136 Answers
Hi, If this is an electric dryer, check the 4" vent going outside and make sure it is clean.
If this is a gas dryer, you caould have the coils on top the gas valve going bad.
Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
I have a 2007 Saturn, Aura. Heater does not blow hot, slow coolant leak, & it also over heats. Please help! I'm freezing when I'm in my car!!!
You need to fix the coolant leak, then refill and bleed cooling system, then you will get heat and cure overheating problem too
Dec 16, 2015 | Cars & Trucks
The heat doesn't get hot while, i'm warming the van but when i started driving the get hot what's warm.
First checkup the coolant level in the radiator before you start the engine cold. Top off as necessary. If it's rally low you may need to "burp" the air from the cooling system.
When the radiator is full start the vehicle and watch the temp gauge. Once the gauge reaches the midpoint you should have plenty of heat. If there is still less than adequate heat raise the rpm slightly. If a lot of heat starts to come from the vents with the added RPMs than one of two things has happened.
1. The coolant level is still to low. The added rpm is enough to push coolant up to the heater core but low RPMs cause a loss of coolant flow and thus less heat.
2. The heater core is starting to plug up due to dirty old neglected coolant. The extra RPMs cause more flow which leads to more heat.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 15, 2014 | Chrysler 2000 Town & Country LXi
Heater low heat
check to make sure your cooling fan isn't running constantly, also if your temp gauge says the engine is hot but the heat isn't you have a flow problem. maybe water pump or a clogged/ crimped hose. if your gauge isn't very hot then put some cardboard infront of the grill.
Jan 03, 2014 | 1999 Nissan Quest
I have a 2002 Ford Taurus, I may have a slight antifreeze leak (strange smell when heat is on), however my heat is very tempermental: it takes forever to heat up the car and when it does, it will only blow...
Check the thermostat. It's almost like a "float" that allows coolant to pass through a hose. If it gets stuck, you have heating issues. Since yours seems to fluctuate, I'd bet it's a thermostat about to go. Fortunately, it's easy to fix and inexpensive.
Nov 29, 2013 | Ford Taurus Cars & Trucks
Heater does not put out hot heat just slightly warm after a while
If thermostat has been changed and still not hot enough, I'd take a look at this link for my tip regarding poor heat. Remember to bleed system good and make sure you have heater on when re-filling/bleeding the system. Quite often at idle, it's poor, and when RPM's are increased the heater feels hotter in this case.
( http://www.fixya.com/cars/r3698796-unclog_heater_core_rather_replace )
Oct 02, 2010 | 1995 Dodge Dakota
Heater not hot
does the heater core get hot, check the coolant hoses going to the core to see if both are hot, if they are U have a air temperature control blend door problem, most likely the actuator for the door has failed.
Dec 16, 2008 | 2001 BMW 325
Dryers Logo
Top Dryers Experts
Marvin
Marvin
