Question about Fisher and Paykel DEGX1 Electric Dryer
I had water in my basement, now the dryer does nothing. fuses are good.
There is a controller board that is located on the bottom left of the dryer unit. This board is just over $100 as a replacement from FP. In most cases replacing this will fix the problem although I just replaced one on a gas dryer and it powered on but nothing else worked. The power light came on when plugged in but couldn't turn it off or change the setting from no heat dry. Could of been because no gas was attached but that is a question for another day.
This board will get wet and burn out when there is about 5" of water in the basement.
Posted on Aug 03, 2009
Kenmore electric dryer model #11062812100 10 in of water in basem
check where the power cord enters the machine,there is a terminal block and that may be a problem there,check the thermal fuse located on the vent housing,it could be a corroded high resistance connection from the water to the control board,unplug unit and remove each connector even the ribbon cables to the controls as if they get a bad connection they cant transfer a signal to operate the machine
Apr 04, 2010 | Dryers
My basement flooded with about a foot of water. Now the dryer wont turn on. Is there an internal fuse or reset? or am I looking at a new dryer?
Make sure the motor still turns (by turning the drum) Then, with the unit unplugged, check the thermal fuses and thermostats. Also, make sure you still have power to it (that the breaker didn't trip from the water.)
Mar 14, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Kenmore gas dryer model 110 97576200 will not heat up
WHERE IS THE LINT SCREEN ON YOUR DRYER? ON TOP OF THE DRYER? IF SO, UNPLUG DRYER. REMOVE THE PANEL IN THE BACK, HAS NINE SCREWS(1/4 NUT DRIVER). THE FUSE IS A SKINNY TWO TERMINAL DOWN NEAR THE BOTTOM. USE AN OHM METER TO CHECK. IF NO READING, THE FUSE IS BAD, REPLACE AND HOPE NOTHING ELSE LIKE THE IGNITOR IS BAD TOO. GOOD LUCK...
BOYNISMO@YAHOO.COM
Jul 07, 2009 | Kenmore 75944 Gas Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
DRYER TURNS ON BUT WON'T TURN
Does it do anything elso or it's completely dead?
Is the fuse on the picture is the one you bypassed:
The thermal fuse
partimage.aspx?imgid=z3bqljbfahrfote1mjkzmy9mufcvc290b2hwdhjhcc8%3d copy n paste this: http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx
- The wiring diagram which may help you. "Did it solve your problem?"
Mar 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Dec 19, 2008 | Kenmore 63942 Dryer
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
98 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
