Question about Saeco Royal Cappuccino Espresso Machine
Hi the cappuccino button pushed only goes for a few seconds and stops before you have to push it over and over again to get the job done. What can I do to correct this problem
  • 1,089 Answers
Hi
There is a program in your menu for the cappuccino that can be turned off so it will go al long as you want.
You might try also holding the button down and see if it will go longer? Some buttons are programmable by holding the button down until you get the amount you want, then release it.
Posted on Jul 01, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Printer does not print
Instructions
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Locked light is stuck on
Are you pushing the button repeatedly or pushing it once and and holding it on for 4-5 seconds? Just push and hold it on for a few seconds till the lock light goes off.
May 25, 2014 | Kenmore 16602 / 16604 / 16609 Built-in...
Forgotten how to turn it on. It seems to be set on timer. Oops
push stop button for a few seconds until it beeps or the readout changes. unplug,,,,,plug back in....push "Select" or "menu" button depending on which machine you have....push again and again until the program you want is on the display or readout. Then push the "start" button ....Don't push any timer buttons or arrows!
Dec 04, 2011 | Kitchen Appliances - Others
I have had this rca lyra mp3 player for along time and its been setting idle a few years .I put a fresh battery in it and it wont come on .Im wondering if i forgot how to turn it on .I was holding the on...
hi Arnie, 1. make sure you put the battery in right way first before I can help further.
2. for this player to come on you just push play button(which is a on button,if you push it again meaning you pause) and if you push stop button meaning is stop and if you hold on it for few seconds the player goes off.
Jul 01, 2010 | RCA Lyra RD1071 MP3 Player
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Screen goes Black about 1 or 2 seconds after powering up.
you have problem wit the lamp just plug in another once you removed the back cover and if the lamp stays on the it is 100%. you do not need original lamp. Any 15" lcd lamp that fits will do the job. HA HA well done
Ahmad
COMPBITS.COM.AU
Jul 06, 2009 | Computers & Internet
Need instructions for setting armitron 40/6735
This should help with the 4 buttons:
Push the button Lower left and hold it for 2 seconds and you will see a number flash. This is for the alarm setting.
Push the same button again and a new screen with the time comes up and the seconds are flashing.
Push the top right button again and the minutes will be flashing.
Push the top right again and the hours will be flashing
Push the lower right one time and the time moves ahead 1 hour
Push the lower right again for the next hour and the time moves again. Do this as many times as you want to change the hours. Each time you reach 12:00 the screen will change the “A” and “P” to tell you if you are in AM or PM. Time.
You can set the minutes in the same way as you do the hours by pushing the lower right (set) button. The when done push the lower left to stop the set-up
After you set the time or the alarm, push the lower left button again to stop the set-up.
Mar 16, 2009 | Armitron Watch
Saeco Royal Cappuccino Espresso Machine Logo
123 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
