Question about GE JES1456 Microwave Oven
I have a JES 1456 GE Sensor microwave oven purchased at Walmart about 3 years ago. It has worked great up until now and it just quit. It is blacked out and does nothing. It quit without a sound while in use. No sounds. no smells. nothing. I played with it for a while pressing all the buttons, opening and closing the door and once it lit up but when we went to use it, it blacked out again.
    Sergeant:
  • 268 Answers
Sounds like you have a thermal reset opening up on the unit and disabling it till it cools down. Make sure all air intakes are clear of debris, papers from the counter , etc. also make sure no dust covering air intake holes. Do you hear a fan running when the unit starts?? If not, bad fan, burnt wires. bad main board. Like a lot of my other posts, maybe a bad fuse and fuse holder. Check for brown flux coming out of shiney metal end of fuse, where it meats the ceramic body. Replace fuse and fuse holder. Sometimes fuses do just get tired and barely open, not actually blow, then just expansion and contraction of the element inside will make the unit work and then quickly shut off. Cheapest way is just sub the fuse and give it a try. Cost you a dollar or two, if that works replace the fuse holder too.
Posted on Aug 18, 2017
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM1630BJ Microwave went completely dead with no power
Sounds like the bulb shorted, which is very common, and the first time it blew the fuse.
It sounds like when you put the new fuse in and tried it again, the bulb was still shorted, and this time it damaged the board.
We see (and repair) thisa lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about aweek.
Atour Web site, we have a videoavailable showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure oftenoccurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often alsoaffect the exhaust fan operation, too. The lights and fan can beinoperable or stuck on too.
Details of our serviceand critical safety information and disassembly information is at oursite, and our link is at ourlisting hereon FixYa.
Feel free to contact me directly (and please remind me of yourfull model number) for more information & help.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave working when door opens
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Dec 13, 2008
  • 13 Answers
SOURCE: ge microwave oven wall smelling wire burn!!!!
time to put it to rest
Posted on Jan 02, 2009
  • 140 Answers
SOURCE: GE less than 2 year old microwave runs, doesn't heat
The problem you are having is that the magnetron that actually does the heating has gone bad. The fact that everthing works fine rules out any type of bad fuse since there is only one 15amp ceramic fuse in most cases in the unit itself. The magnetron is located behind the control panel on top and has some cooling fins on it. Replacing it if you are a do-it-yourselfer is pretty easy provided you can find one at local electronic supplier or on the internet such as www.mwoparts.com if you would like to see what it looks like. It is held in place with typically 4 screws. It has two to three terminals depending on make and model and age. With everything unplugged it comes off easily enough with no desoldering or soldering to do. There is a High Voltage Capacitor and Diode that could be bad also, but without being able to check it in person it would be difficult for me to tell that they are. In my experience the magnetron is the first thing I replace and have never replaced a capacitor or high voltage diode in the past 20 years. Good luck and God bless.
Posted on Jan 23, 2009
I have a GE JES 1456 WF001 sensor microwave, of coarse it stopped working but it gave me no warning what so ever.However its not doing anything, want light up, can't press any buttons, what's the...
It may be a blown fuse or thermostat / TCO / thermal cutout.
Dec 18, 2011 | GE Microwave Ovens
Sear Advantium 120
Disconnect it and connect bac to power. check the fuse. If nothing works is either the fuse, the cable or the power supply unit.
Apr 03, 2008 | GE Advantium 120 Convection/Microwave Oven
I have a GE Profile Advandium 120 SCA1000DWW03 microwave. Recently noticed arcing or sparking at the base of the back wall when microwaving. Any ideas or solutions? Was purchased about 5-6 years ago
This is not good, the magnetron is arcing because there is exposed metal. The manufacture provides a special enamel white paint that insulates the interior to prevent this. I would contact GE or appliance repairman and not use the oven until this is dealt with, running the microwave unchecked will eventually burn out the magnetron.
Feb 06, 2011 | GE Microwave Ovens
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 microwave - Fan only works on 'low' speed
Only working on low would probably be either a bad blower motor or a bad main circuit board. I dont remember ever having to replace a blower, but the main board has relays that switch back and forth for what ever speed you are trying to use. Problem is the main board will be quite expensive. May want to look at prices on new units. And remember on a new unit you get full factory warranties on everything.
Oct 02, 2017 | GE JVM1440 Microwave Oven
GE JVM1640 won't heat
These microwave ovens have a series of door switches. One of yours has gone bad or a plastic finger on your door mechanism that pushes the switches is worn or broken off. They are commonly called NC or NO swithes some ovens have up to 6 of these working together.If you have no expertise in this field consult a repair shop. Please rate me
Comment posted on Jan 12, 2009 there are two types ,normally open and normally closed, NO NC . u have to check continuity on each one and each switch will have a diagram on the side showing its in use position. I hope this has been helpful
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I bought a ge microwave ( model JES738WJ02)SERIAL FR909449U)from walmart store in greenville north carolina little less than 3 weeks ago. this oven is getting VERY VERY HOT WHEN I HEAT SOMETHING IN IT OVER...
Go to geappliances.com and click on the "Service and Support" link on the left-hand side of the screen. On the next page, click on the "Contact Us" link. You have the option of using their knowledge base to see if any of the posted questions will help you. Or, you can send an email to them to address the issue and you can call them directly. If you decide to call, I would recommend the "GE Answer Center", or the "GE Warranty Management" links. Since you just purchased the item recently, they still may honor a replacement or free repair if there's something wrong with the appliance. Since you can't find your receipt, your serial number may come in handy to prove this point. The first two letters "FR" indicate that this applaince was manufactured in February of 2008 which makes it about 3 months old. Most manufacture warranties are for one year. With this information and a store number of the Wal-Mart where you purchased the item from, you shouldn't have any problems resolving this issue. I hope this information is helpful to you.
May 12, 2008 | Microwave Ovens
GE JES1456 Microwave Oven Logo
403 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
