All the cords are working I will take off the back and check the bulb then I will let you know if it is or not. Thanks for all the help you have given so far. Definitely allot better than the daewoo customer service.
    Genius:
  • 1,847 Answers
Also check out the this link..
http://www.slelectronics.net/daewoo/tvrepkit.htm
Thanks
Kindly rate the answer
K
Posted on Jul 01, 2009
Clean bulbs on a D56W136D
Hello. Here are the steps to a perfect cleaning job:
  1. Power down TV and unplug all cables attached to back of TV, including TV power cable. You never want to risk touching components inside the TV that could be hot, including a rear-projection bulb.
  2. 2 Unscrew and remove back cover of TV. Have someone help you if the TV is big or back cover is heavy. Most TVs will unscrew easily, but refer to your TV owners manual for specific instructions.
  3. 3 Locate and unscrew bulbs housing unit. Your owners manual can again be used to find specific instructions on how to properly unscrew bulbs housing unit.
  4. 4 Clean bulb with soft cloth and cotton swabs. Never let your bare hand touch the bulb. The oils on your hands can cause the bulbs to deteriorate prematurely. Be gentle with the cotton swabs to avoid breaking or cracking anything.
  5. 5 Reattach bulbs housing unit.
  6. 6 Reattach the back cover and have someone help you again if you needed help taking the back cover off.
  7. 7 Attach all media devices and power cords.
  8. 8 Power on the TV and begin watching.
Joe
Thanks for choosing Fixya!
Nov 29, 2010 | RCA Televison & Video
I dont know how to change te bolb
Open the door to the dryer. Look directly in the back of the dryer, and you should see a rectangular cover with a phillips head screw. Before you begin, first unplug the cord from the wall. Then, unscrew the cover and remove it. Unscrew the bulb, and then replace it with the new bulb. It should be a 10 watt appliance bulb. But double check the old one, before you buy the new one. If there's no info. on the old one, then get the 10 watt bulb. If this works for you, great! If not, feel free to contact me back. Good Luck!
Jan 05, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Non-dell power cord wont work
You can buy a universal cord they will work with your dell.
Take the one you bought back for a refund tell them you want a universal that will work with a dell also take your dell model or the old cord with you.
Please don't forget to rate me
Let me know if this helped
Feb 13, 2009 | Dell Inspiron 6000 Notebook
Please help Fan not working in Neff U1451
Hi, the fan is one part and the bulb another. They are not connected. If the bulb isn't working simply unscrew the bulb lens and replace the bulb. About the fan motor, sometimes they cease up because the build up of grease at the back of the oven. You can try to remove the insid back plate that covers the element and fan, and try to rotate the fan manually. Try to clean it and test again. Last resource, it needs a new fan motor.
Cheers
Feb 08, 2009 | Neff U1721 Double circotherm Electric Oven
RCA DLP PROBLEM AFTER POWER OUTAGE
Hi I am vortash I have a number of these sets with faults on the go at the moment they seem to have a life of their own or not as the case may be ?. I have just downloaded the manual for this set and it has a fault finding section you might try it was from http://www.safemanuals.com this may help I am unsure still looking for an actual schematic let me know how you get on
Regards Vortash
Dec 16, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
TV turns on but no picture
I'm sorry, but there is littel help we can provide without the make and model number. There are numerous reasons for no picture. Can you please provide some additional details? For example, is there any blinking of a stanby light? Do you hear the high voltage startup (snapping like sound)?
Thanks,
Dan
Sep 03, 2008 | Televison & Video
Mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Mar 14, 2008 | Mitsubishi HC3000U Multimedia Projector
Stuck on "warming up"
Sorry, forgot to get back to ya..
anyway, remove control panel cover, remove button panel, you will see a little tab right at the top, push that down and unlock and discconect, remove small ribbon on the underside. use torx driver and remove screws so that you can remove the whole top gray housing, you want to access where the scanner bulb comes to rest, there will be a black plastic cover over the scanner bulb, REMOVE THAT PIECE, its about 2" wide by 10" long, unclip it by putting small screwdriver in small rectangular slots and pry lightly to the right, there are little tab locks in there.
With that removed, just put things back loosely to see if the warming up stops when turning on or trying to use scanner, if everything works well, do alittle cleaning and put thing all back together.. this should solve your warming up promlem..
GoodLuck TAP
LET ME KNOW
Feb 15, 2008 | HP PSC 950 All-In-One InkJet Printer
No power
Bulb is definitely not cause of your problem.Normally lamp light will blink when it's defective.Dead means PSU problem .Some projectors have a overheat switch which switches off supply till manualy reset,you need to open the projector.
Samir
Oct 30, 2007 | BenQ PB6100 Multimedia Projector
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
