Question about American Standard Home
Tank on back of toilet seems loose,but no leaks
  • 224 Answers
Behind the bowl are two nuts with bolts that extend into the tank. Use a large screwdriver to hold the bolts (they have screw heads) and use a 6" cresent wrench to torque the nuts closer to the tank. Be careful as you can crack the porcelin pretty easily if you overtighten.
Posted on Jul 04, 2009
Toilte leaks in front have chk the lines and find no leaks. Is it the toilte
If you have found no leaks on the supply line, be sure to check the seal between the tank and the bowl. This is a common source of leaks, especially on older toilets that have seen much use.
Before you do that though, check carefully at the base of toilet to see if its possible any water is appearing from under the toilet. Your toilet sits on a seal, most often made of wax (sometimes rubber) that seals the water and waste from the toilet into the drain pipe. Normally, those seals last many years. Flush the toilet 3-4 times and observe whether any water seeps out under the toilet. Give it a few minutes (4-5) and recheck. If it is leaking, the fix is pretty simple: Shut off the water, disconnect the source water line just so you won't risk breaking it, and remove the 2-4 toilet bolts. Rock the toilet gently and pull straight up until the seal comes loose. The beeswax seals seem to work the best. Scape off as much of the old wax as you can, and set a new one. They are very inexpensive, and sell for around $2-3.00 USD. To reinstall, remove the protective lining (if present) on the wax, place the ring on the toilet, not the flange and carefully place it straight down onto the flange. Try not to make a mistake - line it up carefully. Press down on the toilet's seat area, maybe rocking yourself a little, until you can see the toilet is back in position.
Next, VERY CAREFULLY tighten the toilet's mounting bolts, a bit at a time, until secure. Over-tightening can break porcelain toilets, so be careful.
OK - either that's fixed or you've ruled it out. Next is the tank seal. Unfortunately, the only way to get to it is take the tank off. If its come to that, first go to the hardware store and secure a replacement set containing the tank seal, a new pair of brass bolts, and the bolt seals. Expect to pay around $4-5.00 USD for the set. The job is pretty easy, you use a wide flat-bladed screwdriver to loosen the (usually) brass screws in the bottom of the tank after shutting off the water and while an assistant holds the nuts from the bottom. You COULD do if yourself, but an assistant makes it easier. Carefully lift off the tank, and you'll see the seal. Remove it, and replace it with the new one, being careful to put it in the right direction, as they are usually cone-shaped. Set the tank back on, put the screws back in, using new seals/bolts (just for good luck) and reassemble. BE CAREFUL when tightening the bolts!! You can easily crack the tank if overtightened.
This is a lot of writing, but just to give you an idea, I could probably change a wax ring in 10 minutes, and the tank seal in 15 or so. Best wishes -
Jun 09, 2014 | Electronics - Others
Toilet leaking from tank when I flush. Want to know how I can fix the problem
Common areas for tank leakage are the bolts that attach the tank to the bowl and the gasket between the tank and the bowl. The hardware could simply be loose or the seals could be deteriorated and in need of replacement. Begin by flushing the toilet to find the source of the leaking. Check for moisture on the tank attaching bolts under the tank and tighten the bolts carefully to avoid cracking the tank. If moisture is oozing out of the joint between the tank and the bowl, it will be necessary to drain and remove the tank to get access to the gasket for examination and possible replacement
Jun 28, 2013 | Home
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
Toilet is leaking between tank and seat. the water that is collecting on the back of the toilet is blue. what does that mean.
Check for any loose connections or a crack in the pump casing. Check all the rubber fittings also for any holes or cracks.
Oct 11, 2010 | Eljer TITAN 15" Two-Piece Toilet -...
When you sit on the ring it veers off to the left and you are left sitting there crooked. How do we adjust it?
See if nuts on studs on bottom where it mounts to the floor & flange are loose. If they are loose tighten both of them evenly. If they are tight you will need to replace wax ring that is between toilet & floor.Turn off shutoff water valve to toilet. Flush once holding down handle to let tank drain. Remove both nuts & lift toilet off flange. Remove wax ring. Scrape all old wax off toilet & floor flange. Install new wax ring. Set down toilet on ring & snug nuts evenly. Sit on seat & apply your weight evenly to distribute wax & level. Retighten nuts. Turn water back on. Allow tank to refill. Flush toilet & check for leaks.
Sep 30, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
I installed the tank on the bowl hand tight, but it seems loose
thats a tough call, i used to battle with this when i was out in the field fixing many toilets,...if it don't leak, it's tight enough,..concerning the rocking, i used to place little shims under tank to stop it rocking,....don't force nothing,.and make sure your hand tight is good-n-snugg. good luck, good question, cracklin joe
Jan 04, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
Tank bolts leaking
washer bolt in the tank? try a little silicone caulking as well. The tank may be cracked
Jun 20, 2009 | Plumb Pak /Keeney Mfg. 456268 Do it Toilet...
Home Logo
226 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
